Undergrad NMR Remote Sensing: Does US Army Detect Buried Weapons?
seanscon
TL;DR
It should be possible to detect RF radiation from NMR of ground targets - but does anyone know of an actual algorithm ??
Hi
I was watching
Generally - you can activate use a strong magnetic field on ground, perturb it, and the pick the signal up with a satellite. The result would be in 60 to 1000 MHz ( VHF Television ) by a satellite.
But the post also says, that US army is using it to detect burried weapons.
Does anyone know how such a thing would provide the magnetic field? Is Earth's magnetic field sufficient
Does anyone know some details? Some algorithms that can actually perform this work?
Any publication would be wonderful as well.
seanscon said:
Summary:: It should be possible to detect RF radiation from NMR of ground targets - but does anyone know of an actual algorithm ??
Welcome to PF.
Don't believe anything seen on "The Curse of Oak Island". It is not a peer reviewed journal.
The curse is that it will waste your time and your life.
Even though NMR can work on the ground, and satellites can "see" things from high above, NMR imaging requires you put the article in a strong magnetic field like a hospital scanner.
Ground penetrating radar is less limited by ground conditions than is NMR.
There will be no articles about NMR imaging from space. It is a fiction.
Likes berkeman and sophiecentaur
That is not entirely correct. There is a such as thing as low-field NMR, where the Earth's field is used.
The key idea is -obviously- to just use very good sensors (SQUIDs or more recently vapour cells) for the detection. Much of this research has been funded by the US military since one application is detection of explosives. It could in theory also be used for medical purposes (MRI scanners), although the resolution is not great.
That said, low field NMR only works in a well shielded environment (although you can use active shielding rather than mu-metal) and there is definitely no way to detect the signal from space.
