NMR: Simple Question About Aligning w/ External Magnetic Field
  • Context: Undergrad
  • Thread starter Thread starter nickypoo
    Nmr
The discussion revolves around the alignment of nuclear spins in an external magnetic field, particularly in the context of nuclear magnetic resonance (NMR). Participants explore the reasons behind the distribution of spins between low and high energy states, the role of temperature and entropy, and implications for experimental setups like the Stern-Gerlach experiment.
  • Some participants note that approximately half of the spins align with the magnetic field (low energy) while somewhat less align against it (high energy), questioning why some would align against the field.
  • One participant introduces the Boltzmann statistics to explain the fraction of spins in high versus low energy states, emphasizing that at room temperature, both states are populated due to entropic factors.
  • Another participant mentions that thermal agitation leads to almost equal populations of spin states at room temperature, with the energy difference being small compared to thermal energy.
  • Some participants discuss the concept of entropy in relation to the number of available microscopic states, suggesting that there are more configurations where spins are not all aligned in one direction.
  • There is a question about the behavior of a single electron's spin in relation to magnetic fields and entropy, with some arguing that the concept of entropy is less relevant for a single particle.
  • One participant points out that the discussion is primarily about many spins in NMR, not a single particle environment, and that the thread is quite old.
Participants generally agree on the influence of temperature and entropy on spin alignment but express differing views on the implications for single particles versus many spins in NMR. The discussion remains unresolved regarding the specifics of how these concepts apply to single electrons and their behavior in magnetic fields.
Some participants highlight that the energy differences between spin states are of the order of thermal energy, which complicates the interpretation of spin alignment in various conditions. The discussion also touches on the limitations of applying concepts like entropy to single particles.
nickypoo
Ok, well I'm not really sure if this is the right place to post this, but I have a simple question regarding nuclear magnetic resonance.
I know that the "spin" axis of a proton will align along the external magnetic field. That's pretty simple.
What I don't understand is the direction they align.
I'm under the impression from what I've read that approximately half will align with the field (low energy) and somewhat less will align against the field (high energy).
Why do some align against the field in the first place? It seems to me that they would naturally assume the lowest energy potential.
Sorry if I'm viewing this too simplistically.
The fraction of high to low energy states occupied is determined bny the Boltzmann statistics:
##n_h/n_l =\exp(-(E_h-E_l)/kT)## where ##E_h=-E_l## is the energy of a spin in the high/low energy state and k is the Boltzmann constant. Only at very low temperatures will all spins be in the low energy state. At room temperature it is entropically favourable for both energy states to be populated almost equally.
Funny thing is that you can make a compass needle lay in oposite direction to the external field if you are precise enough. It is just a state where torque of the field B on the moment μ is zero: \vec{τ} = \vec{B} x \vec{μ} ! The same is with protons, but you don't have to be precise cause this allignement is one of their two possible quantum states.
So why would the spin of a single electron be equally likely to "line up" with a magnetic field as opposite with it? How does the entropy come into play?
it is not equally likely. There is greater chance for spin to be aligned parallel to the field than antiparallel.
Yes. But keep in mind that this difference is about few ppm. Insignificant on the long scale but still fair enough for NMR phenomenon.
The answer is that thermal agitation at room temperature results in almost equal spin up and spin down populations at equilibrium. This is because the energy difference between the states is small compared with the mean thermal excitation energy. Increasing the static (B0) magnetic field strength increases the energy difference, increasing the equilibrium population in the parallel (ground) state relative to the anti-parallel (excited) state. This, in turn, is why there is always pressure to increase the field strength at which NMR instruments and magnetic resonance imagers operate--the SNR of the NMR signal improves.
The entropy is a function of the number of microscopic states available. There is only one state where all the atoms align one way. There are many more states where some of the atoms align the other way.
Curious! If a Stern Gerlach experiment were performed close to zero degrees temperature with a strong enough field would you expect to get only one line?
But what about a single lone electron?
I'm not sure that this applies directly to that. The Stern-Gerlach apparatus reads out the spin states of atoms passing through it but doesn't say anything about how those atoms were prepared, and it is for the latter that temperature would matter. If you somehow prepared all atoms to be in a single state, which certainly would be done at low temperature, then yes you would get one line.
The entropy of a single particle isn't a particularly useful concept
You are derailing this thread a bit. Note that in a typical NMR experiment, you are dealing with a lot of spins and with energy difference between the two spin states that are of the order of the thermal energy. It is not a "single particle" environment.
This thread is also almost a year old.
Zz.
  • · Replies 0 ·
