NMR versus GC/MS, HPLC/GC, HCLtitration, meltingpoint test
  • Thread starter Thread starter chantal029
    Nmr Test
Nuclear Magnetic Resonance (NMR) testing is essential for detecting the effectiveness, quality, and quantity of chemical products, particularly in identifying wrong raw materials, over-reactions, and isomers during synthesis. While techniques such as Gas Chromatography-Mass Spectrometry (GC/MS), High-Performance Liquid Chromatography (HPLC), and melting point tests provide valuable information, they do not match NMR's capability to analyze complex mixtures without prior knowledge of components. For purity assessments, Liquid Chromatography-Mass Spectrometry (LC/MS) is recommended over NMR, especially for compounds requiring 99% purity. A combination of these methods is advised for comprehensive analysis.
  • Understanding of NMR spectroscopy principles
  • Familiarity with GC/MS and HPLC techniques
  • Knowledge of purity assessment methods, including LC/MS
  • Basic concepts of organic chemistry related to isomers and synthesis
  • Research the principles and applications of NMR spectroscopy
  • Learn about the capabilities and limitations of GC/MS and HPLC
  • Explore the use of LC/MS for purity determination
  • Study the significance of melting point tests in purity analysis
Chemists, laboratory technicians, and quality control analysts involved in product analysis and purity testing will benefit from this discussion.
chantal029
Is it true that only a NMR test is able to detect the effectiveness, quality, quantity of a product?
That it is able to detect wrong raw material, over-reaction, or isomers occurring during synthesis?
But what about the other tests like GC/MS, HPLC/GC, HCLtitration, meltingpoint test. Is one or a combination of these tests not able to do the same as a NMR, tell you the effectiveness, purity, quality of a product? How do these other tests compare
to NMR?
Chemistry news on Phys.org
if i remember correctly from o-chem class 10 years ago:
GC can tell you how many components you have and the relative amounts
MS can tell you the mass of those components and some structure info
so long as you know what by-products to expect this should/could be enough
with NMR you can determine the relative amounts of products and byproducts so long as you know what you are looking for and the spectrum isn't too messy. Multidimensional NMR can further clean up a messy spectrum - for example: you can see peaks from one molecule hiding with the peak from another molecule in a 1-D spec
if you don't know what is in the mixture you'll want all 3 - with this information you could determine the composition of an unknown mixture.
NMR is not sensitive. If you need something 99% pure, you won't be able to confirm that with a typical NMR run. Something like LC/MS can be used to determine purity. NMR can also be extremely complicated once your molecules start getting bigger or have all sorts of sterochemistry involved. It is good to always use both.
In my experience, a starting material that was involved in manufacturing an analgesic related to ibuprofen, was tested for extreme purity by melting point/freezing point. GC was available, but wasn't sensitive enough and the impurity was not completely resolved using capillary columns. It was an extremely slow analysis with freezing point determined with an extremely accurate thermocouple reading plotted on a chart.
The story was that the unwanted isomer was responsible for liver damage in early work on the compound.
  • · Replies 19 ·
9K
  • · Replies 37 ·
  • · Replies 21 ·
