Nobody understands quantum physics?
278 replies · 24K views · last reply
The problem with Bohr is that he is so unclear in his writing that it invites such "philosophing" about "what might the author have wanted to say", and that's why QT till today is often displayed as something mystic. I find Bohr' and Heisenberg's writings did a bad job in "interpreting QT", because they were too philosophical rather than to wrap off all the dust of the unclear quarter of a century of "old quantum theory", where you had no clear picture of how to describe "quantum phenomena", leading to indeed vague and inconsistent pictures like "wave-particle duality", which was substituted by Bohr just by the even more obscure "complemantarity principle". I think with modern QT there's no need for such philosophical distortions of a very elegant and clear mathematical formulation which just does what all deep physical theories do, i.e., summarizing many empirical facts into a scheme of a few generally valid basic principles, with which all these and (hopefully) many to be discovered phenomena in the future can be described.
It's like with Newton's principia: There were a lot of empirical facts about the motion of planets, moons, and the Sun, including very accurate ones like Kepler's Laws, but it could be simplified by building a theory which systematically reduced the necessary basic principles to a minimum set of "fundamental laws", i.e., Newton's postulates/axioms, clear definitions of the relevant quantities like time, position, mass, force, etc. as well as the general law of the gravitational interaction, which could be formulated based on the clear definitions due to the postulates and then proven to be indeed generally valid (until GR refined the description even more). Also this "reduction" of many empirical findings to a few fundamental laws, from which "the phenomena could be derived" went along with a higher level of abstraction, although in Newton's case it's not so obvious, because the use of Euclidean geometry is very familiar to us from elementary school on. The even more abstract math of "infinitesimals" and analytical geometry was again a step to the use of more abstract descriptions, but making the whole description even more powerful.
You can go on in the history of physics and find that the more general and the more comprehensive you get with the theories the more abstraction is needed. Today we use pretty abstract concepts like group theory and topology to describe Nature with more and more accuracy and larger and larger realms of validity, and I'm pretty sure that the solution of the remaining puzzles (on the most fundamental level, that's for sure a fully self-consistent quantum theory including gravitation) will enforce the use of ever more abstract ways of thinking.
LittleSchwinger said:
That's all he meant. If one reads his essays he usually says that in the following sentence.
Maybe? Who knows! My impression is that it is Bohr's own fault that his writtings are misunderstood. My impression is that von Neumann's writtings are misunderstood too, but that it is much harder to blame von Neumann himself for that.
Similarly here if you listen to the talk, all Feynman means is that the probability calculus of QM is not reducible to some "visualisable" classical events playing out like you said.
Feynman speaks very clear, and he is normally understood correctly. And if people "quote" him wrong or out of context (like "shut up and calculate (Feynman)"), then they often do it intentionally to promote some sort of agenda.
Just saying. It is nice to try to defend Bohr, because if you are able to understand what he was trying to say, then you see that he had a very good understanding of how nature works. But to imply that understanding Bohr would in any way be similar to understanding Feynman, that is frankly ridiculous.
I think the following nicely describes the issue with Bohr:
https://physicsworld.com/a/the-bohr-paradox/
Feynman for sure is another caliber. Here's always very clear and a role model of a "no-nonsense physicists" and also obviously a very diligent teacher as long as you restrict yourself to his scientific writings (research papers but also real textbooks). Of course, one should not take his popular-science writings at phase value, because you cannot expect even a genius like Feynman to get the science write without the use of the only adequate language to communicate it, i.e., math. Obscurity comes usually always due to the avoidance of the adequate mathematical language.
vanhees71 said:
Bohr is right that the only adequate language to discuss physics is math.
I think mathematics is obviously the only way to make quantitative statements anyway as it will involves measures and numbers in some form.
My own emphasis on Bohrs legacy is not the math. It is needed always, you cant get around that. Its just as natural that trying to find a way to speak quantitativley about rational "degress of belief" leads to some sort of probabality theory.
"purely symbolic mathematical algorithm, which connects one classically specified set of conditions to another."
For me the main insight from Bohr is that the quantitative description of even the subatomic domain (only indirectly observable via perturbation and monitoring the response) must be defined in terms of relations between the classical variables, which we at least in principle can know objectively by weak interations that does not alter the variable in question.
This is also the problem of CH - you need a "macroscopic/classic" context to even define QM as it stands. We have this in subatomic physics so its right on as long as we stay away from gravity cosmology. This should be an insight to that entertain the idea about a qantum state of the the whole universe.
I always interpreted Bohr as clear and honest. I always thought that as beeing the first generation into QM, he perhaps got the relation to classical mechanics best.
/Fredrik
Nice post. It probably just comes down to what styles of writing fit with one personally. One of my personal favourite essays on quantum theory is Schwinger's at the start of his "Symbolism of Atomic Measurement" book.
I'm not sure how to respond to this. Certainly Feynman was a clearer writer than Bohr. I wasn't even "defending" Bohr. Just confirming that in this case Bohr meant what vanhees71 guessed at, since he states it pretty plainly in the relevant essay and that in general among most authors it seems to me that when you read their essays in context it's fairly clear what they meant.
Neither an entire "defense of Bohr" or a detailed comparison of Bohr and Feynman as authors was intended.
This IMO is the heart of the problem. To observe the microscopic, one needs a microscope. One must build a macroscopic device for the measurement that is of necessity coupled to and a definite part of the system being observed. The wonder of QM is a formalism that allows one to abstract this macroscopic part of the system away. Want to measure the x-component of spin? You need to build a suitably prepared system along with the x-component spin measurement device. Want to measure the z-component? Well, build a z-component measurement system. It's a whole different system.
BTW, is no sense do I see this as a problem with CH.
The main conceptual hurdle posed by quantum mechanics seems to be that it imposes a hard limit on the nature of measurement. We know that wave functions probably exist, but physically there’s no experimental way to probe or dissect the process of how wave function collapse occurs, or even to verify that the dynamics of wave functions that don’t collapse intermittently (i.e. the wave functions we never ever ever see) are anything like the dynamics of wave functions that do produce an observable signature. It’s incredibly weird that the ‘unitary’ dynamics of quantum mechanics plays out over a seemingly very non-unitary background statistical ensemble of many tiny rapidly and repeatedly collapsing wave functions that probably define our perception of classical time evolution. The one approach to examining this (the classical-quantum divide) that comes to mind, short of a double slit apparatus for very small black holes, would be to try to iteratively extend EPR style experiments to include more and possibly more complex degrees of freedom. But that would be expensive and laborious…
Agree with all except last paragraph at least in the context of unification.
This is IMO the precise problematic way we mix up and hide and as you say do away with physics background conditional complexions in a mathematical structure, that we soon forget has physical correpondence and thus potentially evolving. And from that point on the "effective math" some of us take for "proven structure" may misguide us forward
I feel that on this point Bohr did not mix it up like some seduced by its math, this is what i meant with honest. Note that im not saying here we dont need math that is obvious.
/Fredrik
Yes, this chapter (and the entire book) is a masterpiece. It's utmost clear and no mysteries. It's clearly science and not philosophy ;-))!
You just need, e.g., a Penning trap with its magnetic field to decide which spin component (or rather which component of the magnetic moment ##\vec{\mu}## you want to measure. You can do that with an amazing accuracy. There's nothing mystic with this but very well understood (even analytically solvable!).
There's no limit on measurement. I don't know, where this fairy tale comes from. It's often written in popular-science textbooks, but it's wrong.
What quantum theory tells us is that it is impossible to prepare a quantum system such that all observable take determined values. A state of "complete knowledge" is a pure state, and it's uniquely determined, when preparing the system such that a complete set of compatible observables take determined values. Usually observables which are not compatible to this complete set then to not take determined values.
At the present stage of our knowledge, we cannot say whether there is a collapse of the quantum state that goes beyond standard QT or not. For sure it's not the hand-waving addition to the well-defined formalism of QT one often reads in textbooks promoting some flavors of the Copenhagen interpretation, which include a collapse postulate. I've never found any necessity to assume a collapse to apply QT to the description of real-world experiments.
Further there's no hint at a "classical-quantum divide" aka "Heisenberg cut". Today ever larger systems have been used to verify "quantum effects". E.g., the ~10kg mirrors of the LIGO experiment show quantum behavior.
https://arxiv.org/abs/2102.12665
https://doi.org/10.1126/science.abh2634
I agree, but it's well understood and solid thanks to that it "connects one classically specified set of conditions to another". Fortunately this holds for what is dicussed here.
(But for a more complete reflection: when the macroscopic conditions are in motion, due ot considering gravity/unifications it seems to me it's less "well understood" as the clarity rests on the fixed, non-dynamical context. But this is beyond a B-level discussion of course)
Edit: I don't think "classicaly specific set of conditions" means that someone suggests "classical mechanics" is correct(or better than QM), it's just a metaphor for a set of conditions nthat we have solid confidence in, on par with how we did think of things in classical mechanics. So this does not mean we still don't have decoherence explanations, I don't think there is a contradiction.
/Fredrik
In order to understand Bohr, it maybe could be helpful to delve into the philosophy of radical constructivism (https://en.wikipedia.org/wiki/Radical_constructivism).
In “Farewell to Objectivity” (Systems Research, 13(3), 279–286, 1996. 187), von Glasersfeld remarks:
“The conceptual revolution that has shaken the 20th century is more profound than the one initiated by Copernicus, who dislocated the human being from the cherished position at the hub of the universe. But even if mankind was relegated to an insignificant minor planet, it could still maintain the belief that it represented the crowning achievement of God’s creation and that the human mind towered over everything else because it was able to perceive and understand God’s work, at least in its great lines. The 20th century has shown this belief to be illusory. Whatever the stuff is that we call knowledge, it can no longer be considered a picture or representation of an experiencer-independent world. Heinz von Foerster has said this with consummate elegance and precision: ‘Objectivity is the delusion that observations could be made without an observer.’” [bold by LJ]
In “Towards a radical constructivist understanding of science” (Foundations of Science 6, 1–30 (2001), Riegler writes:
“Radical Constructivism (RC) is the insight that we cannot transcend the horizon of our experiences. Experiences are all we can work with; out of experiences we construct our world. Thus, there are no mind-independent entities on which our cognition is based. This does not imply that Radical Constructivists deny the existence of such an objective world populated by mind-independent entities, the reality. Neither do they assert its existence. RC is agnostic.“
I think that Bohr held an epistemological position that is compatible with radical constructivism, i.e., that any mind-independent reality is inaccessible.
I agree with one caveat: no matter what words used by tradition, the word "mind" is bad because it makes some people think that this litteraly has to do with "human observer". My impression is that this is not what Bohr ever meant. Instead Bohr thought that the "classical background" together, makes up the "observer". I think Heisenberg had a different angle to it, I think Bohr was more clear.
/Fredrik
Another nice one come to think of it is Kemble's textbook. It actually came out in 1937, but there were very few copies until its Dover reprint in 1958. He has a very good conceptual exposition of quantum theory, focusing on the fact that one cannot prepare a system so all quantities take definite values.
The mathematics is well understood by many. The physics, not so much. I think it is still relevant to say "nobody understands QM" because 99% of those who think they understand it, don't understand the physics, their abilities to wield the mathematics notwithstanding.
No other theory, attracts so much argument about interpretations of the meaning of the mathematics as QT, without any way to distinguish between interpretations.
I think 97% might disagree but I wouldn't want to speak for them.
DaveC426913 said:
The primary purpose of a theory is to make testable predictions, and it does that extremely well.
Comprehensibility is a secondary function. :wink:
Yes. And the primary purpose of economy is to make money, making goods is its secondary purpose. And the primary purpose of education is to pass exams, getting knowledge is its secondary purpose. And the primary purpose of science is to publish scientific papers, creating new knowledge is its secondary purpose. It is quite common in this society that the method of verification (of achievement of the original abstract purpose) has turned into a primary purpose, just because it's more concrete and measurable.
What's the purpose, for example, of predicting the probability of Higgs decay?
Mathematics also has its deep conceptual problems that are not understood by many. How many people understand Godel theorems, or continuity hypothesis, or Banach-Tarski paradox, for instance?
The “answer to the question that does not answer the question” is emergence - properties of the macroscopic system (such as “phases of matter”) exist that are not properties of the subatomic system.
They are "properties" of the field l(as solid particles have not been found yet in this part of the galaxy).
The field is not the chair, the chair is emergent from the field, a partucular configuration and this is the only consistent way to think about the world. We have something that manifests as something which it is not there in its constituents with defined properties. This brings us closer to raising the concept of observation to a level that is more fundamental than the concept of chairs.
Cogito ergo sum
But how many people worry about this when balancing their checkbook?
We should probably also define what it means to understand the math of QM. Does that mean knowing how to perform the common calculations? Or does it include understanding the foundations? Does it include understanding the infinite space of mathematical implications (e.g., theorems in the theory of quantum computing)?
Also, is understanding the theory without interpretation the same as understanding the math? Is there even an agreement about the mathematical structures QM should use (or which ones correspond to nature)? I still see people writing papers claiming that different variations of Hilbert space might have different implications for things like quantum gravity.
Popular understanding follows in time.
There was once a time when Einsteinian relativity was brain-breaking stuff.
There was once a time when Newtonian motion was beyond the ken of most.
I also believe Feynman said in one of his documentaries something to the effect of “science has no obligation to be psychologically pleasing”.
John Mcrain said:
Listen just 1 minute, what does it mean when he said nobody understand quantum mechanics?
This sound like comedy
If you watch from 1:08:08 to 1:10:00 I think Feynman answers your question.
And ultimately...
What is agents purpose of predicting the future?
Does it have a choice?
Under what conditions can the agent learn?
Are bad learners and bad predicting agents likely to be ubiquitous in nature?
/Fredrik
But it is known material that can be taught, and the info&math students typically understand it. Well, maybe except for Banach-Tarski paradox, where they only understand the math, but not how to "resolve" it.
What is also not so well understood (by the info&math students) is why Gerhard Gentzen (by proving that ##\epsilon_0## is well ordered) and later Kurt Gödel (by using his higher order dialectica interpretation) could still prove the consistency of Peano arithmetic. But I guess those are not deep conceptual problems, but simply less standard material.
The Banach-Tarski paradox might indeed be a conceptual problem, because how do you deal with the fact that your mathematical statements "there exists ..." don't mean what they are supposed to mean? You introduce measurable sets, and hope that this reduces the gap. But can you ever prove that your mathematical statements now mean what you believe that they say?
This is beginning to sound a lot like philosophy of science.
gentzen said:
What is also not so well understood (by the info&math students) is why Gerhard Gentzen (by proving that ϵ0 is well ordered)
Are you named after him?
