Non-commutative operations on natural numbers and rooted trees
127 replies · 17K views
Homework Helper
In semi-response to Organic's post I thought I'd half take up one of his challenges:
Let S = NxT be the product of the natural numbers, N, with the set of all rooted finite trees (or directed graphs satisfying the obvious conditions), embedded in the plane, with the natural ordering on the branches/leaves.
Let C be the subset of all possible { (n,t) | n in N, t a tree with exactly n edges}
We define an operation + on elements of c:
(n,t)+(m,r) = (n+m,s) where s is the tree obtained by gluing the tree r onto the end of the first leaf.
The subset (n,t) with t the trivial tree with 1 leaf and n edges, forms a copy of N under addition.
We define * to be (n,t)*(m,s) by
(((...(((n,t)+(n,t))+(n,t))+...)+(n,t))
where there are m-1 addition signs.
again (n,t) with t the tree with n edges and 1 leaf, is a subset that forms a copy of N under multiplication.
neither + nor * are in general commutative, and I doubt they are associative either, but I can't be bothered to check, they are both well defined binary operations from CxC to C.
Now shall I claim that C is the new non-commutative natural numbers or not?
but he's already using the naturals inside his definition to define his "new naturals" there is nothing there to suggest these new objects should replace the natural numbers.
So, you don't understand that the standard natural number is a trivial private case of infinitely many structural/quantitative information's forms that ignored by Standard Math paradigm.
Do you get it?
A NUMBER is first of all an information's form, and to understand this we MUST explore our cognition's abilities to define this information's form, as I do here:
http://www.geocities.com/complementarytheory/count.pdf
Dear Matt:
I am really happy that you did so !
I will come back only in this weekend.
Best
Moshek
Do you get it?
Nothing to do with my post here then?
When you, in your theory, assign these trees to certain sets, how do you decide which belong in the same set? You do it by counting the things involved in the construction, therefore you are explicitly using the counting numbers. Otherwise how did you decide how to group certain things together?
Nothing to say about my construction here then? This is the answer to your request ot show you something that behaves like your structures do. The difference is I don't make any large and unjustified claims about what I'm doing.
Well I am still here.
Organic:
Matt open a great opportunity here
Please see this as a real challenge for you.
Yours
Moshek
I will come back in few days.
I'm not in the slightest against you putting extra structure on the natural numbers, I just would like you to realize that you don't need to, and in fact you are requiring their 'non-existent' quantity only property when you describe the extra structure. The natural numbers come only as the idea of quantity, even their additive and mulitplicative structure arises from this.
It is not your ideas that annoy me; it is your mistaken assertions about them and mathematics.
The philosophical aspects of it are of minimal importance, especially until such time as you even begin to demonstrate you understand what you write.
Here let me demonstrate a rigorous approach using the things I defined above.
Define the complexity of (n,t) to be the number of leaves of t - this is equal to the number of paths from the root to the end of a branch, by the definition of tree.
If all paths from root to branch have the same length, let us define the symmetry thus:
Each set of consecutive leaves, take the smallest subtree containing them, call this a cutting. If the tree can be separated into r isomorphic cuttings that only intersect at the root, we say it has symmetry degree r.
A tree with different length paths we call asymmetric.
Characterization of N inside C: it is the set of elements of symmetry degree 1 with path lengths maximal among (n,t) for each fixed n.
Moreover it is equal to the subset of elements of complexity 1.
That's how you write maths that other people can understand. You use terms everyone knows, or can look up knowing it will agree with your terminology. Anything new you define so that it is unambiguous.
If we denote the degree of (n,t) as n.
Then n is prime iff all trees of degree n are of complexity 1 or asymmetric. How's that for you? Is this the kind of thing you had in mind when you cahlleneged us to find some ordinary mathematics that does what yours does? As you've never even shown us what yours does of course it's a little tricky.
Matt Grime,
Your construction has nothing to do with my natural numbers because,
by your definitions, uncertainty AND redundancy are ignored and also the complementary relation between multiplication and addition.
To understand it better please look at my ET's and find by yourself
that the Equations Trees can be changed by their structure, when quantity remains unchanged:
http://www.geocities.com/complementarytheory/ET.pdf
Please show me this property in the standard natural numbers, where each change is a quantity change (because any change in no-redundancy_no-uncertainty information form immediately changes its quantity).
You right because you don't know what you are doing.
Why you so afraid to understand that the "quantity-only" natural numbers are only partial information of the structural/quantitative information that I show in my system?
Do you really cannot understand the paradigm shift the QM gave to the scintific world?
Each one of these structural-quantitative products is unique, therefore can be used as a building-block for much more interesting and richer information form, then your “quantitative-only" unique [n] result, which is nothing but a private-case of no-redundancy-no-uncertainty structural-quantitative product of my number system.
We can clearly see this here:
http://www.geocities.com/complementarytheory/ETtable.pdf
The big paradigm's shift is QM and not SR, please read this:
http://plato.stanford.edu/entries/qm-copenhagen/#4
This paradigm's shift, does not exist in the basis of Standard Math language, because Boolean Logic or Fuzzy Logic are private cases of what I call Complementary Logic, that an overview of it can be found here: http://www.geocities.com/complementarytheory/BFC.pdf
Through my point of view Natural numbers are complementary elements, based on discreteness(particle-like)-continuum(wave-like) associations.
The information structure of the standard Natural numbers, is only a private case of these associations, for example:
More details can be found here:
http://www.geocities.com/complementarytheory/POV.pdf
Man is no longer an observer but a participator, which its influence must be included in any explored system.
It means that we cannot ignore our cognition's abilities to create Math language anymore, as I clearly show here:
Definition:
1 minus the reciprocal of the complexity is the uncertainty of (n,t)
Therefore the natural numbers are a private case where there is no uncertainty
Demonstrate I am wrong.
I declare that my numbers are complementary objects that indicate the paradigm shift to a quauntum viewpoint of mathematics.
Define the redundancy of (n,t) to be n minus the length of the longest path through the tree from root to branch.
The usual natural numbers are a 'private case' where the redundancy is zero.
I can remove all reference to N from the constructions involved in this if you feel like it too.
1)Redundancy AND uncertainty
2)Show now where is the tree?
Code:
(1*4)              ={1,1,1,1} <------------- Maximum symmetry-degree,
((1*2)+1*2)        ={{1,1},1,1}              Minimum information's
(((+1)+1)+1*2)     ={{{1},1},1,1}            clarity-degree
((1*2)+(1*2))      ={{1,1},{1,1}}            (no uniqueness)
(((+1)+1)+(1*2))   ={{{1},1},{1,1}}
(((+1)+1)+((+1)+1))={{{1},1},{{1},1}}
((1*3)+1)          ={{1,1,1},1}
(((1*2)+1)+1)      ={{{1,1},1},1}
((((+1)+1)+1)+1)   ={{{{1},1},1},1} <------ Minimum symmetry-degree,
                                            Maximum information's
                                            clarity-degree
                                            (uniqueness)
3) You call t an Organic numbers but you don't understand what Are Organic numbers.
Organic numbers cannot reduced to quantity alone, because their organic information structure cannot be ignored.
It means that each information form is at least an organic stuctural/quantitative unique element as we can find here:
I defined uncertainty and redundancy for my trees, which are not just quantity. Given any quantity, which I called degree there are many elements of that degree. We can label [n] as all the trees of degree n.
Show that my construction has less right to be called the correct interpretation of the new QM paradigm of mathematics? I've got uncertainty, redundancy, quantity, and operations that I call complmentary addition and multiplication. So why am I wrong and you right? They're all based on discrete and continuous constructions such as nodes as branches which encompass all the requirements of the continuum and such.
So I now contend that my number system is the correct one, yours but a pale attempt to obtain this level of complexity and accuracy.
Matt,
It is very simple to show that you don't understand my system, for example:
Please find the unique labels of {1,1,1,1}.
Be aware that what you call a function is first of all a reflection of your memory.
Matt,
What did I call function?
I'll will call the tree (4,t) where t is the tree with just the root node and 4 leaves from it) the element (1,1,1,1), or perhaps I want the trivial tree of degree 4? I can't remember what you're claiming (1,1,1,1) represents, tell me and I'll tell you which one it is.
I am not claiming my system is your system, but it that it has all the features of your system, with the added bonus of containing a genuine copy of N inside it, as well as a non-commutative deformation of it. And therefore has just as much right to be called the correct system of the 'natural numbers' of mathematics. It contains all possible tree structures of degree n, so it remembers the 'structure' of each number as well as its quantity. I can change the structure and not change its quantity (degree).
Looks like it's a winner.
Oh, and to make it more rigorous, I only defined symmetry degree for symmetric trees, so I will define the symmetry degree of an asymetric tree to be -oo,
BY writing (4,t) you did nothing.
Show us how this general (n,t) can define the number of (6,t) unique elements, for example.
the number of elements in [n] ie the set of all (n,t) t a tree with n edges, is exactly the number of (rooted) trees with n edges. You can count them if you like.
There is one element of[1], 2 elements in [2], there are I believe 5 elements in [3]..., call the number of elements in [n] the rank of n:=r(n)
there are then (r(n),t) elements of degree n, where t is the trivial tree with r(n) edges and 1 leaf. Recall the trivial trees form the trivial N structure of quantity only.
Why, how many structures are there for each quantity in your theory?
Perhaps, if my answer didn't satisfy you, you could tell me what the question actually means because I don't understand what you want. None of the things you've asked me about have been defined in this theory using those words. Please exlpain what you want me to define now, and I'll endeavour to add it in.
For every question you ask, as well, could you show what the answer is in your system too, so we know that you're not just asking deliberately meaningless questions, which is how they appear as you don't adequately explain what you want.
Matt,
Here are numbers (1,t) to (5,t):
Find the rule and give the number of (6,t)unique elements.
That question doesn't make sense in english. I can tell you there are as many elements in my set [6] as there are rooted trees with 6 edges, off the top of my head I don't know how many of those there are. There is probably a simple generating function for them but I can't be bothered to work it out. Is that what you wanted to know? The rank of 6? Using my definition of rank as above?
Anyway, that diagram refers to your trees, not mine. I am not saying our systems are the same, I'm just saying that mathematically I can define a system properly with all the innate structure of yours but in a way that anyone can understand.
Try rewriting the question so it conforms to the basic rules of English and perhaps I can answer it.
And why are you using my notation for your objects?
You know what? show how you can find the number of trees of (6,t)
in your system.
It's the number of trees with 6 edges. Get a pen and paper and work it out. It is tedious but doable, hint find the correct recusrive formula. Why, what are the number of diagrams in your theory with quantity 6?
67 unique ordered trees (by their symmetry degrees) for quantity 6,
without left-right switches.
But you see, what is important here is not just the quantity 67 but the unique structure of each tree.
By my research here:
Any number is at least an association between our memory (the continuum) and some element(s)(discreteness).
Therefore these trees are the basic models of the associations between our memory and a given quantity.
The standard natural numbers are private case of one and only one association tree, which is the maximum broken symmetry tree of any given quantity.
Because any number is first of all memory AND element(s), then no association's structural form can be omitted by us, when we count.
Therefore N members of standard Math are trivial elements, and any other number system that constructed by them is also a trivial number system.
My theory of numbers fixes this triviality by exposing the hidden internal information structures of any given quantity.
Because my organic numbers are an ordered number system by symmetry degrees, we can use them as non-trivial powerful tools that can help us to start a non-trivial research of the complexity itself.
A simple example:
To say 2+3 is not enough because in my natural number system we need to know what internal structure of 2 and what internal structure of 3 we are going to add to each other.
Quite possibly true, you are now into the philosophy of mathematics. There you are free to state what you will. I will not and have not argued against that position. I have always argued against you misusing mathematical terms, and not telling anyone what you mean clearly.
Here I've demonstrated a mathematical object that does all the things you want and that you claimed mathematics wasn't able to do. It possesses attributes labelled by all the terms you gave, has well defined binary operations (for all inputs, unlike yours) and is a genuine non-commutative extension of N, which it contains as a subobject.
Incidentally is 67 the answer in your system or mine?
The formula for the number of trees (rooted, ordered, etc) with n edges is I believe
sum r(i)r(j) where i+j=n-1 and i,j are non-negative, and r(0) is defined to be 1. Which gives, r(1)=1, r(2)=2, r(3) =5, r(4)=5+2+2+5=14 r(5)=14+5+4+5+14=32 r(6)=32+14+10+10+14+32=112 I think.In my system the Natural numbers are the subobject corresponding to the case of zero redundancy and zero uncertainty, just as you wished.
Matt,
I do not say that Math cannot do it, I say that Math not use these internal symmety degrees as the fundamental property of The natural number definition.
If we use these symmetry degrees as the basis of Natural number definition, then any Natural number become a much for powerful/sensitive tool for Math language research.
But if you add this structure to the definition of natural numbers, then you are changing the definition, tautologically. This stucture is not needed to define the natural numbers, it can be deduced from their existence, and is therefore not a "first order" property of them. I use that in a non-technical sense. All the objects, trees etc, you use are out there already known and studied. You've given no compelling reason to justify the assertions you've made about why the natural numbers must have links to uncertainty, or quantum objects. Philosophically I believe you have the wrong emphasis, but that difference stems from your need to define mathematics subjectively and use this idea of being aware of its being observed. I don't see any mathematical reason for that. Philosophically that is a different matter; I have no strong opinions either way. But that is my personal philosophy of mathematical research, which is of no interest to anyone but me at the moment.
I just wish you would at least define unambiguously the terms you use so that misunderstandings cannot arise.
Matt,
Please show me some Mathematical research where trees as symmetry degrees are studied, including detailed structural results.
How do you know that these symmetry degrees are not "first order" property of them?
Show me some research that proves it.
For example: 6 gives, let us say, 67 unique ordered symmetry structures.
In 67 we are talking on very big quantitative result of unique ordered symmetry structures that are ignored by Standard Math point of view, and so on...
If you explain what you mean by symmetry degree perhaps I could.
And I said that I wasn't using "first order" in its proper meaning. Intuitively, you are using the quantity idea to enumerate your 67 trees of quantity 6. If the (structureless) natural numbers weren't available how could you use your "natural numbers" to count your "natural numbers"...? Especially as the 'number' of trees of a given quantity is more than any of the quantities defined so far - you need to "define 67" to count the structures of "quantity 6" ... This isn't rigorous, nor do I intend to make it so; I'm offering a philosophical discussion of the ideas because that way none of us can be wrong, just disagree, possibly.
Matt,
please look at these Equation Trees(=ET) :
Code:
     1                1                1
    +            2 = +            2 = +
     1                1                1
4 = +       4 = +            4 = +
     1                1                1
    +                +            2 = +
     1                1                1
         1                     1
        +                 2 = +
     3 = 1           3 = +     1
4 = +   +       4 = +
         1                     1
         1                     1
Let us say that notation '4' is the integral side of ET4,
and '1 1 1 1' notations are the differential side of ET4.
Now, take each ET as a one organic element.
From this point of view the quantity of each ET remains
unchanged , but the structure of each ET is unique and it is not
ordered by quantity change but by the symmetrical degree of each ET.
Again we count the ET's not because of quantitative change, but because of
The inner structural change of each ET.
Now, we can find exactly 9 unique ET's in quantity 4:
These ET's can also be represented as:
Code:
(1,1,1,1) <------------ Maximum symmetry-degree,
((1,1),1,1)                  Minimum information’s clarity-degree
(((1),1),1,1)
((1,1),(1,1))
(((1),1),(1,1))
(((1),1),((1),1))
((1,1,1),1)
(((1,1),1),1)
((((1),1),1),1) <------ Minimum symmetry-degree,
                                 Maximum information’s clarity-degree
By Peano axioms we are using only this ET (((((1),1),1),1),...) Which is a private case of one and only one ET structure.
But what about the rest ET's of ET4?
Any changing in ((((1),1),1),1) form cannot be but a quantitative change, because he has no "inner space" that can be changed.
But this is not the case of the rest ET's
Code:
(((1),1),1,1)
((1,1),(1,1))
(((1),1),(1,1))
(((1),1),((1),1))
((1,1,1),1)
(((1,1),1),1)
that have "a room" for internal changes.
Any ET with "free space" for structural changes is ignored by standard Math.
By my structural/quantitative approach this information is not ignored.
1) we indeed using peano axioms to find the next basic quantity, then for each basic quantity we define all its inner structures, and then we move to the next basic quantity by using again Peanos axiom.
2) Through this attitude we systematically define any possible information structure That can be expressed by ET's.
3) Then we can research their relations upon infinitely many scales, and create more and more interesting models of complex information structures in very efficient ways.
As you can see here: http://www.geocities.com/complementarytheory/ETtable.pdf
The blue x-axis is Peano world, and the magenta y-axis is the rest of ET's world.
Please look again in these examples:
Also, please look again on this paper:
http://www.geocities.com/complementarytheory/ConScript.pdf
Thank you,
Orgainc
I suppose a philosophical position moshek might approve of is that your constructions require more ontological commtiment than is necessary to define the natural numbers.
You need to have trees, symmetry (which you've still not explained) and indeterminacy (ditto) and the notions of very complex sets lying around. In fact your (well, stratman's) construction uses the language of computer programming (let n=1...) and so uses explicilty the natural numbers (as understood ordinarily). Of course that last one isn't a fatal problem in itself. So you not only require the existence of the natural numbers as counting objects, but further ideas, that require ontological commitment that is not necessary in classical mathematics.
Here's a question.
Can you prove something about quantity that cannot be proven through usual mathematical methods?
Allow me to emphasize that I'm talking about purely quantitative statements, not statements where we've substituted your new concepts for existing concepts (e.g. your use of aleph0 seems vastly different from the "quantitative" use of aleph0)
Hyrkyl,
By my point of view -, +, and * have two worlds, the internal world and the external world.
In standard Math the Natural numbers world is only the external world, where each operation chenging the quantity of n.
Let us look on - and + operations on n from ET eyes:
The external result of ((((1),1),1),1) - 1 is (((1),1),1)
The internal result of ((((1),1),1),1) - 1 is (((1,1),1),1)
The external result of (((1),1),1) + 1 is ((((1),1),1),1)
The internal result of (((1,1),1),1) + 1 is ((((1),1),1),1)
So as you see - and + do not changing the quantity but the symmetry degree of each ET.
In this case (1,1,1,1) is the maximum symmety degree and ((((1),1),1),1) is the minimum symmetry degree, for example:
Let us say that we have here a transformation between
multiset {x,x,x,x} to "normal" set {{{{x},x},x},x} and vise versa.
Let XOR be #
Let a,b,c,d stends for uniquness, then we get:
Code:
              Uncertainty
  <-Redundancy->^
    d  d  d  d  |
    c  c  c  c  |
    b  b  b  b  |
   {a, a, a, a} V
    |__|__|__|_
    ={x,x,x,x}
   {a, b, c, d}
    |__|  |  |
    |     |  | <--(Standard Math language uses only this
    |_____|  |     no-redundancy_no-uncertainty_symmetry)
    |________|
    ={{{{x},x},x},x}
[b]
                Uncertainty
  <-Redundancy->^
    d  d  d  d  |          d  d             d  d
    c  c  c  c  |          c  c             c  c
    b  b  b  b  |    b  b  b  b             b  b       b  b  b  b
   {a, a, a, a} V   {a, a, a, a}     {a, b, a, a}     {a, a, a, a}
    |  |  |  |       |__|_ |  |       |__|  |  |       |__|_ |__|_
    |__|__|__|_      |_____|__|_      |_____|__|_      |_____|____
    {x,x,x,x}        {x,x},x,x}       {{{x},x},x,x}    {{x,x},{x,x}}
                                      c  c  c
          b  b                        b  b  b          b  b
   {a, b, a, a}     {a, b, a, b}     {a, a, a, d}     {a, a, c, d}
    |__|  |__|_      |__|  |__|       |  |  |  |       |__|_ |  |
    |     |          |     |          |__|__|_ |       |_____|  |
    |_____|____      |_____|____      |________|       |________|
    {{{x},x},{x,x}} {{{x},x},{{x},x}} {{x,x,x},x}      {{{x,x},x},x}
    a, b, c, d}
    |__|  |  |
    |________|
    {{{{x},x},x},x}
[/b]
For clearer picture please see the piano model in:
http://www.geocities.com/complementarytheory/HelpIsNeeded.pdf
General conclusion:
The internal structure of any given quantity (finite or infinite) cannot be ignored, therefore the natural numbers are at least structural/quantitative information forms:
Please read also this paper:
Let us say that in the first stage we get an ordered table of infinitely many symmetry forms, and by this ordered table we can start to explore the relations between highly complex different forms of symmetries.
Shortly speaking, we have in our hand a Mendeleiev-like table of symmetries, where Peano axiom symmetries, are only some private case in it.
Another very interesting thing is that from ET point of view any number is an organic form with internal complexity, that can exist iff we take each ET as a whole, which is a paradim shift in the concept of a NUMBER.
And this paradigm shift is based on this simple test:
Any number is first of all an information form, therefore any aspect of information form MUST be researched by us, where our cognition’s abilities to research information MUST be included too.
Form this point of view, redundancy AND uncertainty cannot be ignored, and through this approach(which is not an extra approach but the MINIMAL approach to understand the natural number concept) we can clearly show that the standard natural numbers are only a one and only one private case of verity of information forms, which are ordered by their vagueness degrees from maximum vagueness to minimum vagueness when a given quantity remains unchanged.
The above is the QM paradigm shift that is not understood yet by the current community of pure mathematicians.
For example: Be aware that what you call a function is first of all a reflection of your memory.
That was one of the longest 'no's I've seen.
Hurkyl asked you to use your theory to prove something abou quantity that cannto be proven with the usual concept of the natural numbers.
