NOn-linear equation, when has a solution?
  • Thread starter Thread starter tpm
    Non-linear
The discussion centers on the conditions for the existence of solutions in non-linear equations, contrasting them with linear systems where the determinant must be greater than zero. For non-linear equations, such as f(x_i, x_j, x_k) = b_j, determining the existence of a solution is more complex. The conversation highlights the use of contractive mapping procedures as a crucial method for proving the existence of unique solutions in specific cases, particularly in non-linear differential equation systems. Additionally, the application of quadrature methods in integral equations is mentioned as a challenging area for establishing solutions. Overall, the exploration of non-linear equation theory reveals the need for advanced techniques to ascertain solution existence.
tpm
NOn-linear equation, when has a solution??
For linear system of equations:
A_{ij}x^{i}=b_{j} (implicit sum over repeated indices)
a necessary and sufficient condition to exist is that |detA| >0
but what happens whenever you have a Non-linear equation:
f(x_{i},x_{j} , x_{k})=b_{j} ??
How do you know it will have a solution or not??...
the problem arises mainly in NOn-linear equation theory..how do you know that equation:
\int_{0}^{\infty} K(x,y,f(x),)dy = g(x)
has a solution applying a 'quadrature method' ??
Mathematics news on Phys.org
Well, for non-linear diff.eq systems, you may prove, in special cases, the existence of a unique solution function in some neighbourhood of the initial value.
A crucial tool in deriving this, is the use of a contractive mapping procedure.
For algebraic non-linear systems, in so far as you can prove you get a contractive mapping by iteration should also guarantee a solution.
Perhaps there exist less crude tools, I dunno.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 21 ·
  • · Replies 36 ·
