Normal and exponential-normal (?) distribution
  • Context: Graduate
  • Thread starter Thread starter mahtabhossain
    Distribution Normal
9 replies · 3K views
mahtabhossain
Dear Users,
For normally distributed random variables x and y's p.d.f.:
[tex]\frac{1} {\sqrt{2\pi \sigma_x^2}}\exp\left\{- \frac{(x - \mu_x)^2}{2 \sigma_x^2}\right\}[/tex]
and
[tex]\frac{1} {\sqrt{2\pi \sigma_y^2}}\exp\left\{- \frac{(y - \mu_y)^2}{2 \sigma_y^2}\right\}[/tex]
What will be the p.d.f. of ln(x) - ln(y)? Is there any method to find it?
I think the followings are the p.d.f.s of u=ln(x) and v=ln(y) given x and y are normally distributed:
[tex]\frac{1} {\sqrt{2\pi \sigma_x^2}}\exp\left\{u - \frac{(e^u - \mu_x)^2}{2 \sigma_x^2}\right\}[/tex]
and
[tex]\frac{1} {\sqrt{2\pi \sigma_y^2}}\exp\left\{v - \frac{(e^v - \mu_y)^2}{2 \sigma_y^2}\right\}[/tex]
I am trying to find the p.d.f. of ln(x)-ln(y). Any suggestions?
What should the difference or even ##\dfrac{X}{Y}## be? These isn't a random variable anymore.
There is a formula for the general distribution of a function of a random variable which is itself a random variable.
But how we can achieve finite distribution integrals if one variable is in the denominator? And ##ln(X)-ln(Y)## can literally take any values.
If x and y are normally distributed, they can take on negative values with non-zero probability. The expressions ln(x) and ln(y) are not defined for negative values.
Like Stephen said, ln(x) will not be defined at the left end. Maybe you're considering ln (|x|)-ln(|y|)? Or maybe your mean is large-enough that those values are far at the tail end to not worry about them?
Or you can just add the assumption that ##X## and ##Y## are both positive.
Assuming ##Y\neq0## everywhere ##X/Y## is still a random variable.
It is still the wrong direction and requires additional assumptions. Instead of asking what ##\log \dfrac{X}{Y}##means, one should start whether a random variable ##Z## with properties ##\ldots## can be described by a pdf ##\ldots##
Why? Use that ## P(Z:=X/Y < w )=P(X< yw) ; y \in Y## so that ##\int_{- \infty}^{\infty}ydy\int _{-\infty}^{yw} xdx ##defines a distribution for ##Z ## under some reasonable conditions like ## y \neq 0 ## and others. Instead of ##yw## as an integration limit, you can use any function of either, including log. Please double-check, I am on my phone here.
