Normal force on boy at roller coaster crest
  • Thread starter Rwarno
9 replies · 4K views · last reply
Rwarno
A(n) 21 kg boy rides a roller coaster.
The acceleration of gravity is 9.8 m/s
With what force does he press against the
seat when the car moving at 6.7 m/s goes over
a crest whose radius of curvature is 14 m?
Answer in units of N
2. F=ma a=(v2)/r
Fn= ma-mg
Fn= 21kg(6.7m/s2/14m) - 21kg(9.8m/s2)
Fn = 67.335N - 205.8 = -138.465
(my homework database says this is wrong, so i tried...)
Fn = ma + mg
Fn= 67.335 + 205.8 = 273.135
(my homework database says this is also wrong what am i missing or doing wrong?)
2. F=ma a=(v2)/r
Fn= ma-mg
Fn = ma + mg
It looks like you are subtracting the two forces? If he's going over a bump on a crest, that increases his apparent weight, it doesn't decrease it...
Rwarno said:
Fn= ma-mg
Fix this. Hint: The normal force and the weight are in opposite directions. What's the direction of the acceleration?
I tried to add them and the answer was also incorrect. I did it a little backwards(possibly?) and came up with 138.465, Is that correct?
Apply ΣF = ma, making sure that everything has the correct sign.
I tried F=ma in all forms:
the given acceleration : F = 21kg(9.8m/s2) = 205.8 which was said to be wrong
and applying the acceleration using 21kg x v = (6.7m/s)squared divided by r = 11m
which equals 67.3335, which is also incorrect
then i subtracted mg = 21kg(9.8) which was also incorrect
then i added mg, which was also incorrect
The crest radius is 14m, not 11m.
And please add the weight and the extra force, there is no reason to subtract...
i meant to put 14, that's still the right calculation
and i tried it when i added the weight and it was still wrong
and what is the extra force?
Only two forces act, the weight and the normal force. Again, write ΣF = ma, making sure that everything has the correct sign. (Use symbols, not numbers.)
