Notation for nested sums in the Riemann zeta function
rustynail
I was playing a bit with the Riemann Zeta function, and have been struggling with some notation problems.
The function is defined as follows
[tex]\zeta (s) = \sum_{n=1}^{\infty} \frac{1}{n^s}[/tex]
where [tex]s \in \mathbb{C}[/tex]
we know that
[tex]n^s = exp(s\;ln\;n)[/tex]
so I can write
[tex]\zeta (s) = \sum_{n=1}^{\infty} \frac{1}{exp(s\;ln\;n)}[/tex]
but since
[tex]\frac{1}{exp(s\;ln\;n)} = 1 + \frac{1!}{(s\;ln\;n)} + \frac{2!}{(s\;ln\;n)^2} + ... = <br /> 1 + \sum_{n=1}^{\infty} \frac{n!}{(s\;ln\;n)^n}[/tex]
how can I write this ''sum within a sum''? ζ(s) here, if I am correct, would be an infinite sum of terms which are infinite sums.
Thank you for taking the time to help!edit :
Could I say
[tex]1 + \sum_{n=1}^{\infty} \frac{n!}{(s\;ln\;n)^n} = a_k[/tex]
then
[tex]\zeta (s) = \sum_{k=1}^{\infty} a_k[/tex]
Does that make any sense?
rustynail said:
but since
No.
What you can say is that
[tex]\exp (s \ln n) = \sum_{r=0}^{\infty} \frac{(s\ln n)^r}{r!}[/tex]
What you did, simply inverting each term on the right hand side to get [itex]1/\exp(s\ln n)[/itex], is invalid.
This is what you need to use for [itex]1/\exp(s\ln n)[/itex]:
[tex]\frac 1{\exp(s\ln n)} = \exp (-s \ln n) =<br /> \sum_{r=0}^{\infty} \frac{(-s\ln n)^r}{r!} =<br /> \sum_{r=0}^{\infty} \frac{(-1)^r(s\ln n)^r}{r!}[/tex]
This only makes sense for [itex]\,Re(s)>1\,[/itex]...careful!
DonAntonio
we know that
so I can write
but since
edit :
Could I say
then
Thank you DH for the help, and DonAntonio for your rigor, I need to work on that.
But in this part,
[tex]\sum_{r=0}^{\infty} \frac{(-1)^r(s\ln n)^r}{r!}[/tex]
Don't we need to to take the sum of all terms with both n and r, from 1 to ∞? Could I write it as
[tex]\sum_{n=1}^{\infty} \; \sum_{r=0}^{\infty} \frac{(-1)^r(s\ln n)^r}{r!}[/tex] ??
