Numerical solutions for initial value problems and root finding
14 replies · 2K views
Robb
[/B]
It's been a couple of years since differential equations so I am hoping to find some guidance here. This is for numerical analysis.
Any help would be much appreciated.
No. When you go from[tex]\frac{dv}{dt} = -k v^2[/tex]
to:[tex]\int dv = -\int k v^2 dt[/tex]
you can't simply integrate the right side as though v is a constant, because v depends on t, and you don't know the functional dependence of v on t. What you need to do is collect the terms in v on one side and the terms in t on the other side so you have: [tex]\int \frac{dv}{v^2} = -k \int dt[/tex]Try going from there.
-1/v = -kt
v = 1/kt
or is this more accurate: v(t) = 1/kt ?
What about the constant of integration and the initial conditions?
Shoot, I forgot about the constant of integration: v(t) = 1/kt + C
As for the initial conditions I guess I'm not sure. v(0) = v(o). Doesn't this imply division by zero (v(0) = 1/k(0))?
No! You need to add the constant of integration when you integrate, before you invert both sides.
No: as phyzguy said, the correct statement is ##-1/v = -kt + C##.
Robb said:
Yep, I got that. So, v(0) = -1/C
Yes, so keep going. Now you should be able to answer the other questions.
I now have to approximate the root of K. I'm not sure how to find a starting bracket. I know one way is to turn the equation F(k)=27k - ln abs(30k + 1) into two equations; y = 27k, y = ln abs(30k + 1). I've graphed it but the only intersection I can find is at the point (0,0), which we do not want. Any words of wisdom? Thanks!
I suggest using Newton's method to find the value of K. It works for finding roots of an equation of the form F(x) = 0. Here you have F(k) = 27k - ln(30k+1) = 0. Start with a guess for k (I tried k = 1) and iterate until it stops changing. What value do you find for k?
I refuse to look at your posted images, but am willing to comment on typed material.
In this case you want to find the intersection of the two curves ##f(k) = 27 k## and ##g(k) = \ln |30 k + 1|##. For ##k \geq 0## (actually, for ##k \geq -1/30##) you can remove the absolute-value signs in ##g(k)##. We have ##f'(0) = 27## and ##g'(0) = 30##. Since ##f(0)=g(0)=0## and ##g## has higher initial slope, ##g(k)## will exceed ##f(k)## intially. However, since ##g(k)## is a strictly concave function on ##(0,\infty)## (i.e., ##g''(k) < 0## for ##k > 0##), and since ##g## does not grow very fast, the two graphs must cross again exactly once at some value of ##k > 0##. However, that ##k## will be very small, because already by ##k = 1## we have ##f \gg g##. As phyzguy suggested, you can use Newton's method, but another way that looks promising is to expand ##g(k)## as an order-2 Maclauren series of the form ##g(k) \approx 30 k - c k^2## and then solve the resulting quadratic equation.
The graph of ##g(k)## for ##k < -1/30## is a mirror-image of that for ##k > -1/30##, so as ##k## decreases below -1/30 the graph rises up again (from ##-\infty##) and eventually becomes positive once more. That means that there must be a second root at a value ##k < -1/30##.
Note that the value for k you are searching for must be positive, otherwise the projectile will accelerate without limit.
Robb said:
much appreciated.
For what it is worth: you can solve the equation in terms of the so-called Lambert W- function and so can get an immediate numerical value if you use a computer algebra system such as Maple or Mathematica. You can also get a symbolic and numerical solution using the free on-line program Wolfram Alpha.
