Numerical value of complex number
7 replies · 3K views
tomwilliam
I need to understand why
[tex]\left|4+i \right|=4.123[/tex]
and why this is shown by:
[tex]\sqrt{4^{2}+1^{2}}=4.123[/tex]
[tex]i^{2}=-1[/tex]
If I find the square root of this expression squared, then I come up with
[tex]\sqrt{16-1+8i}[/tex] which is wrong...
If you look at an argand diagram, the modulus or |z| of a complex number is the distance from the origin to the complex number. So it's quite simply pythagoras' theorem applied to the problem.
hi tomwilliam! :smile:
the modulus squared, |a + bi|2 is the square of a real number …
it is not the square of any complex number …
|a + bi|2 = (a + bi)(a - bi) :wink:
Thanks. So if I think of the numbers (4, 0) and (0, i) as position vectors on the Argand diagram, where the x-axis is the real number scale and the y-axis is the imaginary number scale, and accept that the modulus is equal to the magnitude of the resultant vector, this means I can ignore the sign of the imaginary part?
Tiny-tim...does the formula you state hold for the modulus squared of any complex number? I would have imagined it was (a+bi)(a+bi)...
hi tomwilliam! :wink:
tomwilliam said:
… this means I can ignore the sign of the imaginary part?
yes … i2 and (-i)2 are the same :smile:
erm :redface:
my formula is right, your formula is wrong :biggrin:
Ok, thanks for your help.
Squaring is not the same as finding the modulus of a complex number.
For any complex number z=a+ib where a and b are real numbers, the modulus is [tex]|z|=\sqrt{a^2+b^2}[/tex] which is obviously always positive since a real number squared is positive, thus a2>0, b2>0 then a2+b2>0, and taking the square root is positive. And this makes sense because we can only have a positive length of a vector.
So yes you can ignore the sign on an imaginary number. [tex]|a+ib|=|-a+ib|=|a-ib|=|-a-ib|[/tex].
[tex]z^2=a^2+b^2+2abi[/tex] which itself is also a complex number, unless a or b are 0.
The modulus of a+ bi is [itex]\sqrt{a^2+ b^2}= \sqrt{(a+ bi)(a- bi)}[/itex].
More generally, the modulus of the complex number, z, is NOT [itex]\sqrt{z^2}[/itex] because [itex]z^2[/itex] is not, in general, a positive real number. It is, rather, [itex]\sqrt{z\overline{z}}[/itex].
