Object is accelerated from rest , find KE
  • Thread starter Thread starter discosucks
    Rest
12 replies · 2K views · last reply
discosucks
An object is accelerated from rest by a force of 32 N over a distance of 18 m. Calculate the
kinetic energy of the object after 18 m
KE = 0.5 • m • v^2[/B]
I can't work out where ill be able to get the mass or the velocity for this one?
Hint: Maybe you won't need those quantities. Any other principles you know that have to do with energy?
You can work them out if you wish , if we can put 'a' in term of 'm' [From the given force] , we can find the final velocity using the equations of motion with constant acceleration [the acceleration is constant because the force is constant] .
But this method is quite long .However, as Mr @Doc Al said, there is a shorter method that has to do with work and energy , could you figure it out?
ummm
well the force by the distance will give me the work done
32 x 18 = 576J
Im almost sure there is a relationship between work and KE but i can't work out what ?:)
discosucks said:
ummm
32 x 18 = 576J
Well, have you studied Work-Kinetic energy theorem ?
Yes but I am not sure i totally understand what to do when with the formula we have
If I am totally honest I am not sure what KEf and KEo stand for .
Work-Kinetic energy says :
"For a particle , a change in the kinetic energy equals the net work done on the particle "
In the formula you give :
KEf stands for final kinetic energy of the object.
KE0 stands for initial kinetic energy of the object.
Ah so the work done is the same as the KE !
I know the work done is 576J so that's the same as the KE!
thanks for your help :)
The work done is equal to the value of KEf - KE0 But KE0 is zero since the object has started from the rest [the velocity is zero] so the final kinetic energy is equal to the work done by the object..:)
Oh perfect i actually over looked that! thaks again for your help!
