Object is accelerated from rest , find KE
  • Thread starter Thread starter discosucks
    Rest
The problem involves an object being accelerated from rest by a force of 32 N over a distance of 18 m, with the goal of calculating the kinetic energy of the object after this distance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need for mass or velocity to calculate kinetic energy and explore whether these quantities are necessary. Some suggest using the work-energy principle, while others consider the relationship between work done and kinetic energy.
Participants are actively engaging with the problem, exploring different methods to relate work done to kinetic energy. There is a recognition of the work-energy theorem, and some participants express understanding of the relationship between work done and kinetic energy.
There is some uncertainty regarding the definitions of terms used in the work-energy theorem, particularly KEf and KE0. Participants are also navigating the implications of starting from rest.
discosucks
An object is accelerated from rest by a force of 32 N over a distance of 18 m. Calculate the
kinetic energy of the object after 18 m
KE = 0.5 • m • v^2[/B]
I can't work out where ill be able to get the mass or the velocity for this one?
Hint: Maybe you won't need those quantities. Any other principles you know that have to do with energy?
You can work them out if you wish , if we can put 'a' in term of 'm' [From the given force] , we can find the final velocity using the equations of motion with constant acceleration [the acceleration is constant because the force is constant] .
But this method is quite long .However, as Mr @Doc Al said, there is a shorter method that has to do with work and energy , could you figure it out?
ummm
well the force by the distance will give me the work done
32 x 18 = 576J
Im almost sure there is a relationship between work and KE but i can't work out what ?:)
discosucks said:
ummm
32 x 18 = 576J
Well, have you studied Work-Kinetic energy theorem ?
Yes but I am not sure i totally understand what to do when with the formula we have
That's the formula you need! What does it say? (In words.)
If I am totally honest I am not sure what KEf and KEo stand for .
Work-Kinetic energy says :
"For a particle , a change in the kinetic energy equals the net work done on the particle "
In the formula you give :
KEf stands for final kinetic energy of the object.
KE0 stands for initial kinetic energy of the object.
I Hope you get the point now ,,.
Ah so the work done is the same as the KE !
I know the work done is 576J so that's the same as the KE!
thanks for your help :)
The work done is equal to the value of KEf - KE0 But KE0 is zero since the object has started from the rest [the velocity is zero] so the final kinetic energy is equal to the work done by the object..:)
Oh perfect i actually over looked that! thaks again for your help!
  • · Replies 16 ·
