Observable universe as a black hole
In summary, the radius of the horizon of a black hole formed by the mass of the observable universe would be 15.6 light years. Matter escaping the horizon would be analogous to a black hole losing mass via Hawking radiation, with the rate of expansion increasing as the rate of evaporation increases.
bcrelling
69
A substance of arbitrarily low density can form a black hole if there is enough of it.
So I took the mean density of the universe and calculated how big it would have to be to form a black hole. It's a surprising coincidence that the swartzchild radius in light years is the exact age of the universe. Is this just a coincidence or is the universe analogous to a black hole?
How did you do that calculation? A black hole doesn't have a volume in the ordinary sense, so it doesn't have a density in the ordinary sense either.
I used the formula:
With m (of universe)= 10^53 kg
This gives 15.6 light years as the swartzchild radius. Which is pretty close to the age of the universe.
I was also thinking that the matter escaping our cosmological event horizon might be analogous to a black hole losing mass via Hawking radiation, with the rate of expansion increasing as the rate of evaporation increases.
You might want to give some thought to the units involved here. Your statement is comparing apples (distance) and oranges (duration).
FURTHER, 15billion years (give or take) is not the distance from which the light now reaching us was emitted (that was much less than 15 billion light years), nor is it the distance the the emitting objects are now (that's more like 47 billion light years)
I think you mean 15.6 billion light-years, correct?
First of all, this has nothing to do with "taking the mean density of the universe and calculating how big it would have to be to form a black hole", which is what you described in your OP. You're just calculating the horizon radius of a black hole with the mass of the observable universe. As I said before, a black hole doesn't have a "volume" in the ordinary sense, so calculating its horizon radius doesn't tell you anything about how much space is inside the horizon. (In fact, that question doesn't even have a well-defined answer.)
Second, if you were going to somehow model the observable universe as a black hole, the key point is not its age, but the surface area of the sphere that encloses it. Not only does this avoid any mismatch of units (as phinds points out), it also takes into account what I said above, that a black hole doesn't have a well-defined interior volume. What you should really be comparing is the surface area of the black hole in question, which is just ##4 \pi## times the radius you calculated (15.6 light-years) squared, with the surface area of a sphere enclosing the observable universe.
Unfortunately, this comparison is not "pretty close". According to our best current model, the observable universe is spatially flat, and has a current radius of about 47 billion light-years, so a sphere enclosing it would have a surface area of ##4 \pi## times 47 billion squared. This is quite a bit bigger than ##4 \pi## times 15.6 billion squared.
(There is also the point that the universe, unlike a black hole's horizon, is not static--it is expanding; but going into that would add even more complications, and I've already said enough to show why the idea of the observable universe being a black hole is not tenable.)
Ok thanks for that guys.
1. What is the concept of the "Observable universe as a black hole"?
The concept suggests that the entire observable universe, which is the region of space that we can see and detect light from, could be contained within a black hole. This idea is based on the theoretical model of the universe as a closed, finite system where matter is constantly collapsing inwards due to its own gravity.
2. How does the size of the observable universe compare to the size of a black hole?
According to current estimates, the observable universe is about 93 billion light years in diameter. This is significantly larger than the typical size of a black hole, which is a few times the mass of our sun. However, some theories suggest that the observable universe could be contained within a supermassive black hole at the center of our galaxy.
3. Is there any evidence to support the idea of the observable universe as a black hole?
Currently, there is no direct evidence to support this concept. However, some aspects of our universe, such as the distribution of matter and the expansion of space, can be explained by the laws of black hole physics. This has led some scientists to consider the possibility of the observable universe as a black hole.
4. Would the observable universe actually look like a black hole to an outside observer?
No, the observable universe would not appear as a black hole to an outside observer. This is because the event horizon, the boundary where the escape velocity exceeds the speed of light, would be far beyond the edge of the observable universe. Therefore, light and other signals from the observable universe could still escape and be observed by an outside observer.
5. How does the concept of the observable universe as a black hole affect our understanding of the universe?
If the concept were proven to be true, it would drastically change our understanding of the universe and its origins. It would suggest that the universe is a closed system and could potentially provide insights into the nature of time and space within a black hole. However, more research and evidence is needed to confirm this idea.
