Odd Quoting Behaviour: One Tag, Two Blocks
  • Thread starter Thread starter Ibix
    bug font quote
15 replies · 2K views
Insights Author
2025 Award
While quoting a post earlier I came across the following interesting behaviour. I pasted a QUOTE tag into a place where the person I was quoting had used large bold text, and accidentally made the QUOTE tag large bold text. This seems to have cause the behaviour below - there is only one QUOTE tag, but it generates two quote blocks. Pasting the QUOTE tag on the previous line (so it was in normal text) then deleting until the "or" was on the same line fixed the behaviour.
Stephanus said:
or
Stephanus said:
For instance, I stay put for 8 years (0,0,0,0) to (8,0,0,0,0)
I just went to edit the above and see that there are two QUOTE tags in the editor view - which explains the two blocks. But I only put one into my original post - something in PF added a /QUOTE and a QUOTE.
Responding to my own thread again, sorry. I guess what's happening is the software fixing badly nested tags - I produced something like
B QUOTE /B /QUOTE
and the forum software has fixed it by adding a /QUOTE and a QUOTE around the /B. That fixes the nesting, but breaks the formatting...
The forum tries to organize tags in a proper hierarchy. Leaving unpaired tags (and <A><B></A></B> is not properly paired) can result in a fix with that attempt, but sometimes it leads to unexpected results.
I've always wondered why, in some posts, quoted text appears bigger than normally would. This thread sheds light on why that is the case.
I guess I was just wondering if there's a better way to fix it - in my example (B QUOTE /B /QUOTE) the forum apparently decided to make it B QUOTE /QUOTE /B QUOTE /QUOTE - but B /B QUOTE B /B /QUOTE would also have fixed it and would have been invisible. Maybe there's some way to say "don't add a quote tag if at all possible"? Or, perhaps more generally, "add inline text tags in preference to paragraph tags"?
In EDIT the strike through and underline tags simply will not turn off. Really aggravating.
eg qwerttyyyy
i tried my best to turn it off after "yyy" but it strikes through anything i type afterward.
following line? as mentor do you see something i don't ?
here' a snip of what i see (you folks taught me that trick)
Oh, the "rich text editor". I suggest to use the normal one (https://www.physicsforums.com/account/preferences), then you see the codes that are responsible for that.
Wow !
Thank Heaven ! Can you guys teach Microsoft that trick ?
That normal editor is sans the handy buttons at top for bold, image, symbols, and doesn't offer quote.
And what i type shows up blue.
Yukk.
I went back to rich text.
Never mind the preferences, you can quickly switch back and forth between the two editors:
  • In the rich text editor, there's an icon at the far right of the toolbar to go to the BB code editor
  • In the BB code editor, there's a blue link under the bottom left of the editor area to go to the rich text editor
I use the rich text editor by default, but if a problem arises I temporarily switch to the BB code editor to see if I can fix the problem from there,
testing editors
one ping
one ping <<< copied and pasted in BBcode editor
successfully switched backlanguages are learned while we are young.
thanks for the new trick, Doc !
Thanks for the new trick, Doc. Tried it , worked first time.
