Odds of Drawing Sequence 4457: Calculating Probability
  • Context: High School
  • Thread starter Thread starter Glype11
    Code Probability
The discussion revolves around calculating the probability of drawing a specific sequence of numbers, 4457, from a set of digits ranging from 0 to 9. Participants explore various approaches to defining the sample space and the implications of drawing with or without replacement. The conversation includes technical reasoning related to probability calculations and the interpretation of outcomes based on different sample spaces.
  • Some participants propose that the odds of drawing the sequence 4457 can be calculated as 1 in 10,000, assuming digits are drawn with replacement.
  • Others argue that if digits are drawn without replacement, repeated digits cannot occur, which complicates the probability calculation.
  • A participant suggests that defining the sample space is crucial for accurate probability assessment, with examples given for different contexts (e.g., phone numbers, passcodes).
  • Some participants discuss the difference between calculating the probability of a specific sequence versus any arrangement of the digits 4457, leading to different probability outcomes.
  • There is a suggestion that the odds of drawing any permutation of the digits 4457 could be calculated, with one participant estimating there are 12 valid permutations out of 10,000.
  • Participants express uncertainty about how to define the sample space in various scenarios, indicating that context matters in probability calculations.
Participants generally agree on the basic probability calculations but have differing views on the implications of drawing with or without replacement and how to define the sample space. The discussion remains unresolved regarding the best approach to defining the sample space and the implications for probability calculations.
Limitations in the discussion include varying interpretations of the sample space based on different contexts (e.g., intentional sequences in phone numbers versus random passcodes) and the assumptions made about replacement in drawing digits.
Glype11
Suppose we have a code: 4457
If these numbers are randomly drawn what are the odds of drawing those numbers?
Here's my approach:
The available numbers range from 0123456789 and there are four columns, minus the numbers which were drawn gives: 1/(10^4-4)~0.01%
Now what about the odds of drawing the exact sequence 4457? Would I simple multiply the above figure by 0.25?
I'm not really sure about either solution. I included my initial reasoning to compare it with the actual solution method.
Presumably the numbers are drawn with replacement. If the numbers were drawn without replacement, you couldn't have a repeated digit.
Glype11 said:
Here's my approach:
No on the part "minus the numbers which were drawn."
Think of this as four independent events, with the probability of drawing a given digit as 1/10. Drawing a 4, another 4, a 5, and a 7 would be 1/10 * 1/10 * 1/10 * 1/10 = 0.0001, which is as you wrote 0.01%.
That's really what you calculated before. The odds of drawing any particular 4-digit number are 1 in 10,000 = ##10^{-4}##.
To define a probability you need to define what is your sample space, for example, the probability of writing 4457 with the sample space ##\Omega = \{4457\}## is 1, while the probability of writing 4457 with ##\Omega = \{x\in \mathbb{N} | x < 10^4\}## is, as you said ##10^{-4}##. But the probability of writing 4457 with ##\Omega = \{x\in \mathbb{N} | x < 10^6\}## is then ##10^{-6}##
I don't understand. Maybe code wasn't the best description.
This a good explanation.
Ok. I wanted to compare drawing that particular sequence vs drawing those particular numbers. To find the odds of drawing those particular numbers without regards to the order would I divide all the arrangement 4457 by 10000 which gives 6/10000 or 6x greater odds vs the particular sequence?
I'm not sure how to define the sample space. The original problem dealt with the last four digits of phone number whose sequence seemed intentional. Another problem involved solving a 4 digit passcode with digits 0 to 9. How would you define the sample space in those cases?
No, it wasn't.
What you're trying to do could use a better explanation.
What do you mean by "all the arrangement 4457" and where do you get 6/10,000?
If you have the numbers 0, 1, 2, 3, ..., 9 in a container and you randomly draw one of them out at a time, with replacement, the odds of getting 4457 are 1 in 10,000. If you pull numbers out, without replacement, there's no way you can get 4457, since after the first 4, you can't get 4 again.
If you have a big wheel, like a roulette wheel, with the numbers 0000, 0001, 0002, ... , 9999, your odds of spinning the wheel and landing on 4457 are 1 in 10,000.
If you don't care about the order and are looking at the odds of getting any permutation of 4, 4, 5, 7 (i.e., two 4s, one 5, and one 7), by my calculation, there are 12 ways out of 10,000. These include 4457, 4475, 4547, 4745, 4574, 4754, 5447, 7445, 5474, 7454, 5744, and 7544.
If this doesn't cover what you're asking about, please be more specific in what you're asking.
Ok then your sample space is the set of all the natural number less than 10 000.
When I started my reply, part of which is quoted below, I don't think you had posted what I've quoted above.
Yes, we're on the same page.
You fully explained everything that I asked.
  • · Replies 41 ·
