ODE with Dirac Delta and conditions at infinity
9 replies · 2K views
Gallo
I'm trying to solve the following equation (even if I'm not sure if it's well posed)
[tex]\partial_{x} \, y(x) + a(x)\, y(x) = \delta(x)[/tex]
with ##\quad \lim_{x \rightarrow \pm \infty}y(x) = 0##
It would be a classical first order ODE If it were not for the boundary conditions and the Dirac Delta. How should I take account of them?
RUber said:
One idea might be to integrate over x.
I'm not sure, what you meant...I would get some kind of integral equation ..
Right - often solutions will involve an integral of some sort.
Can you solve the homogeneous problem ## y_x + ay = 0?##
Then, for the dirac delta, you enforce continuity in the function at x=0, and a jump condition in the first derivative at x=0.
It is a classical ODE except for what must happen at x=0. y(x) must have a jump discontinuity at x=0 assuming a(x) is regular function. Just solve y'(x)+a(x)*y(x)=0 in the domains x>0 and x<0 and patch in the discontinuity.
Right...thanks Dick. Sorry for the error in my last post. First order ODE has jump in the 0th derivative, i.e. the function itself. I have been spending too much time in 2nd order problems.
Thanks, following your hint this is I would go:
if ##y_{\pm}## solve ##y'_{\pm}(x)+a(x)*y_{\pm}(x)=0## in ## \pm x> 0## then ##y_{\pm} = C_{\pm} \, e^{-A_{\pm}(x)} ## and a solution is given by
[tex]y(x) = y_{-}(x) + H(x) (u_{+}(x) - u_{-}(x))[/tex]
where
[tex]A_{+}(x) = \int_{0^{+}}^{x} a(z) dz[/tex]
[tex]A_{-}(x) = \int_{x}^{0^{-}} a(z) dz[/tex]
and ##H(x)## is the Heaviside step function.
Now I need a jump of one in 0, so I impose ##C_{+} - C_{-} = 1##
How do I fix the remaining constant? Moreover I guess that at infinity ##A_{\pm}(x)## has to blow up
where
I don't think you want to reverse the limits in your definition of ##A_{-}(x)##. But otherwise, I generally agree. I don't think you have enough information to fix the constants any better than that.
The Dirac delta right-hand-side is exactly what you would use when calculating a Green's Function. Since ##\delta(x) = 0## when ##x \neq 0##, you need ##y'(x) + a(x) y(x) = 0## for ##x < 0## and for ##x > 0##. If you integrate the de from ##-\epsilon## to ##+\epsilon##, you get
[tex]\int_{-\epsilon}^{+\epsilon} y'(x) \, dx + \int_{-\epsilon}^{+\epsilon} a(x) y(x) \, dx = 1.[/tex]
If ##y(x)## is bounded around ##x = 0##, the second term above vanishes in the limit ##\epsilon \to 0##, while the first term is ##y(+\epsilon) - y(-\epsilon)##, which approaches ##y(+0) - y(-0)## as ##\epsilon \to 0##. In other words, ##y(x)## has a jump discontinuity of magnitude 1 as ##x## passes from left to right through 0.
Thanks, that's what I thought!
