On computing quantum waves exactly from classical action
akhmeteli
TL;DR
An interesting article: "the Schrödinger equation can be
solved exactly based only on classical least action"
Lohmiller W, Slotine J-J. 2026 On computing quantum waves exactly from classical action. Proc. R. Soc. A482:20250413
Abstract:
"We show that the Schrödinger equation can be solved exactly based only on classical least action. Fundamental postulates of quantum mechanics can in turn be derived directly from this construction. The results extend to the relativistic Klein-Gordon, Pauli, and Dirac equations, and suggest a smooth transition between physics across scales. Most quantum mechanics problems have classical versions which involve multiple least action solutions. The associated classical multipaths stem either from the initial position or momentum distribution, or from branch points, generated, e.g. by a multiply connected manifold (double slit experiment), by spatial inequality constraints (particle in a box), or by a singularity (Coulomb potential). We show that the exact Schrödinger wave function ψ can be constructed by combining this classical multi-valued action φ with the classical density ρ, computed analytically from φ along each extremal action path. The construction is general and does not involve any semi-classical approximation. Quantum wave collapse at measurement can be derived from the classical density change. Entanglement corresponds to a sum of classical particle actions mapping to a tensor product of spinors. The results also provide a simpler computational alternative to Feynman path integrals, as they use only a minimal subset of classical paths."
Sorry, I did not provide the link. The article is actually in open access.
  • · Replies 39 ·
  • · Replies 19 ·
  • · Replies 74 ·
  • · Replies 376 ·
25K
  • · Replies 41 ·
  • · Replies 105 ·
9K
