Need Advice: Passing a Ball Bearing from Air to Water
The discussion focuses on the challenge of transferring a metal ball bearing from a column of air into a column of water without allowing water to flow back. A suggested solution involves using a ball valve, which consists of a sphere with drilled holes that align to permit the passage of the ball bearing while maintaining an air seal. The ball valve can be sourced in various sizes, ranging from under 3mm to over 75mm, from pipe supply businesses. A visual sketch of the setup is recommended for better understanding and to refine the proposed solution.
  • Understanding of fluid dynamics principles
  • Familiarity with ball valve mechanisms
  • Basic knowledge of pneumatic and hydraulic systems
  • Ability to create or interpret technical sketches
  • Research the specifications and applications of ball valves in fluid transfer
  • Learn about the principles of air-liquid interfaces in fluid dynamics
  • Explore design techniques for creating effective seals in pneumatic systems
  • Investigate the use of soft adhesives in maintaining air seals during transfers
This discussion is beneficial for engineers, designers, and hobbyists involved in fluid mechanics, pneumatic systems, and anyone seeking innovative solutions for transferring materials between different states of matter.
Frank Dorrian
TL;DR
A one way valve that could facilitate transport of a metal ball bearing between air and a fluid (I.e. water) whilst remaining water tight
Hi all, I'm new to this but joined in the hope someone with more experience could provide some advice. In a personal project, I have a particular design dilemma where I am trying to pass a metal ball bearing (or any other spherical shaped solid) from a column of air into a column of water without the water passing back up.
If anyone has any bright ideas as to what one way valve would be best for this situation I would love to hear your suggestions!
Much love
Frank
:welcome:
I think you need a sketch. My first reading of your description leads me to think of a BB gun firing a BB projectile into a body of water. I'm pretty sure that's not what you mean.
You can drag-drop an image into a post, or click on the Attach files button.
If you think about how the ball is inflated, maybe you'll get an idea. Using the soft glue will allow air to follow the ball.
A ball valve is a ball with a hole drilled through, set in a sphere with matching holes at 180*. Rotation aligns or misaligns the holes.
Plugging one end of the rotating ball would allow a bearing (or other material) to be placed in the remaining end and be rotated to the liquid without breaking the air/liquid seal.
Available from under 3mm to over 75mm at pipe supply businesses.
This may not apply, depending on requirements not available without a sketch.
  • · Replies 39 ·
15K
9K
