Open Loop system with distance-velocity lag and single transfer lag
  • Context: Engineering
  • Thread starter Thread starter Eng studies
    Loop System
The discussion revolves around understanding and plotting the response of an open loop system characterized by a distance-velocity lag and a single transfer lag. Participants are seeking clarification on the definitions and implications of these terms, as well as assistance in graphically representing the system's behavior in response to a step disturbance.
  • Homework-related
  • One participant expresses confusion about plotting the system's response and seeks help to understand the underlying concepts better.
  • Several participants question the clarity of the original problem statement, particularly regarding the definitions of "transfer lag" and "distance-velocity lag."
  • There is uncertainty about whether the "transfer lag" refers to a pure delay or a first-order lag, with calls for clarification on the nature of the system's inputs.
  • Some participants suggest that a detailed signal diagram would aid in understanding the system's configuration and behavior.
  • Concerns are raised about the lack of sufficient definitions in the problem, including the meaning of ##x_i## and the relationship between distance and velocity.
  • One participant mentions that the output change equation may not align with the question's requirements and suggests plotting the step change on a graph.
  • Another participant indicates they are stuck on how to properly plot the graph and seeks further assistance.
Participants generally agree that the original problem statement is unclear and requires further clarification. Multiple competing views remain regarding the interpretation of the terms used in the problem, and the discussion has not reached a consensus on how to proceed with the plotting of the graph.
Limitations include missing definitions and assumptions regarding the system's components, as well as unresolved questions about the nature of the lags involved. The discussion reflects a need for clearer problem statements to facilitate progress.
Eng studies
Xi Xo
---->----[Distance - velocity lag of 4.0s]---->----[single transfer lag if t=5s]---->----
If the system input Xi is subjected to a step disturbance from 2 units to 12 units, plot the response of Xo on a base of time. Determine graphically, and verify mathematically, the time taken for the output to change by 4 units.
Output change = input change (1-e ^-t/T)
Hi All, I have got as far as below, would anyone be able to go over this, I am a little confused with plotting this out onto a graph post equation
Any help would be appreciated, I am hoping to get better understanding before I move onto the next question
4 = 10 (1-e^-t/5)
t = -T in (output change/input change)
t = -5 In 6/10
t= 2.55 x 4s = 10.2
Your question is very hard for me to interpret.
1) Is that "transfer lag" actually a pure delay of 5 seconds?
2) What is [Distance - velocity lag of 4.0s]?
I think it would help me understand if you show a signal diagram with the appropriate transfer blocks.
Hi Thanks for your reply, Scratching my head with this a bit this is all the info given
Diagram is shown as below
"Open loop system with a distance velocity lag and single transfer lag"
Question below
"If the system input Xi is subjected to a step disturbance from 2 units to 12 units, plot the response of Xo on a base of time. Determine graphically, and verify mathematically, the time taken for the output to change by 4 units."
Many Thanks
That's the first step, but you need to do a lot more. It would be best if you made a more detailed diagram that answers the following questions:
1) Are distance and velocity two different inputs or is velocity derived from position (distance)? What exactly is ##x_i##?
2) What does "single transfer lag" mean? Is it a pure transport delay of 5 seconds or a lag?
You should use symbols for Laplace transformations like first-order lag:
And pure transport delay:
I would like to able to answer your questions but what I have posted is all the information given on the question there is no more info provided
Will have a look into above and see how it goes
Is the original question stated exactly as you posted in post #1? It's incomprehensible as it is. You should ask for clarification.
Another thing to ask is if it is (distance-velocity) lag of 4.0 sec. or distance - (velocity lag of 4.0 sec.)?
Hi Thanks for having a look at this, yes the question is as above, I thought id draw it our rather than copying and pasting direct from the homework statement but see below
Still not got any further with it
Then there is a lot that is not sufficiently defined, including:
1) What is ##x_i##? Is it distance, velocity, or both?
2) Is the first block (Distance-velocity) lag of 4.0s? Or is it Distance - (velocity lag of 4.0s)?
3) The second block is called "single transfer lag of t=5s". It is very standard to talk about transport delays, where there is a pure delay of a certain amount, not a lag. Is that what it is? Or is it a Laplace transformation of a first-order lag?
IMO, it is not worth working on this without a clearer statement of the problem.
No problem hence why I have seeked extra assistance on this, will take this back to clarify on the points made and hopefully get some answers to progress this
Your question shows one lag in two steps. I don't believe your question is looking for Output change = input change (1-e ^-t/T).
Then look to plot the step change on a graph and compare your four step change to a value you can find on the graph.
Got there in the end on this one thanks for all the help
I am currently on this question. It is a distance velocity lag followed by a single transfer lag. Output change = input change (1-e ^-t/T) is used. Any help would be greatly appreciated
I am stuck as to how to properly plot the graph.
Just following on... the distance velocity lag is plotted first followed by the single or first order lag???
  • · Replies 31 ·
