Optical Isomerism of [Fe(H2O)6] Complex
  • Thread starter Thread starter broegger
    Isomerism Optical
The complex [Fe(H2O)6] does not exhibit optical isomerism due to the symmetrical arrangement of six identical water molecules in an octahedral geometry around the central iron atom. Consequently, there are no isomers arising from this complex, confirming its optical inactivity. The discussion highlights the importance of understanding ligand interactions, although in this case, the assumption that each H2O molecule occupies a distinct ligand space without interaction is valid for introductory courses. No exceptions to this rule have been identified in the context of hexaquo complexes.
  • Understanding of octahedral coordination geometry
  • Familiarity with optical isomerism in coordination complexes
  • Knowledge of ligand field theory
  • Basic concepts of coordination chemistry
  • Research the principles of ligand field theory as it applies to transition metal complexes
  • Explore the concept of optical isomerism in coordination compounds, particularly in non-octahedral geometries
  • Study the bonding and geometry of hexaquo complexes in detail
  • Investigate the role of hydrogen bonding in coordination chemistry and its potential effects on optical activity
Chemistry students, particularly those studying coordination chemistry, and educators seeking to clarify concepts related to optical isomerism and octahedral complexes.
broegger
Hi. I'm asked the following question:
What isomers does the complex [\text{Fe}(\text{H}_2\text{O})_6] give rise to? Is it optically active?
My answer to the first question would be 'none': The 6 identical H2O molecules are arranged in an octahedral fashion around the central Fe-atom, so there are no asymmetries that could give rise to isomers. Is this correct? It seems to me that this question is phrased as if some isomers do exist (I'm not asked whether they exist or not).
The answer to the second question would of course be 'no', since there are also no optical isomerism.
Am I missing something?
Your argument is insufficient. You could use essentially use the same argument to "prove" the optical inactivity of [Co(en)_3]^3+, but that would be wrong...wouldn't it?
While I'd still be inclined to agree with your result, I have never happened upon the bonding/geometry of aquo complexes myself, to say anything definitive. If there is some kind of hydrogen bonding between neighboring H2O ligands (which I think is unlikely), that might induce optical activity.
I see your point. If we assume that every H2O molecule occupies one ligand space and does not interact with it's neighbors -- would I then be correct? It's an introductory course, so I assume there's no pitfalls.
I'm inclined to say yes, but I'd rather someone who's formally trained in this area weigh in. There may just happen to be some standard result (or exception to the rule) which is completely unobvious to deduce.
Do you have a link to a website talking about bonding/geometry in hexaquo complexes?
16K
  • · Replies 17 ·
  • · Replies 28 ·
11K
