Optics - Three polarizers with 1 moving
  • Thread starter Thread starter DataGG
    Optics
11 replies · 3K views · last reply
DataGG
Thee linear polarizers are in sequence. Let first and last polarizer be crossed (perpendicular to each-other) and the middle polarizer rotate with angular frequency ##\omega##. Show that under such circumstances, ##I## is given by: $$I = I_0 \frac{1}{16}(1-\cos (4\omega t))$$.
The light that strikes the first polarizer is unpolarized.
Please, see the following link (yes, my paint skills are horrible! I tried to make it in inkspace, but I don't know how to work with that program yet!): https://imgur.com/UwQShhx
Malus Law, which is given by ##I(\theta) = I_0 \cos^2 (\theta)##
If you saw the following link, you noticed two angles, ##\theta## and ##\alpha##.
I think ##\theta=\omega t ## and ##\alpha = 90 - \omega t##
So, after the first polarizer:
$$I_1= \frac{I_0}{2}$$
After the second polarizer:
$$I_2= I_1 \cos^2 (\omega t)$$
After the third polarizer:
$$I_3 = I_2 \cos^2 (90-\omega t) \Leftrightarrow I_3 = I_1 \cos^2 (\omega t) \cos^2 (90-\omega t) $$
I can play around with that but I never arrive at the ##I = I_0 \frac{1}{16}(1-\cos (4\omega t))##.
Any ideas?
Any ideas?
You need to monkey around with some trig identities. Step 1: Get rid of that ##90 - \omega t## term. (Get everything in terms of just ##\omega t ##.) Then you are just two identities away from the answer.
Hey Doc, thanks for answering.
I did do that in paper, which I'll copy to latex below:
$$ I_3 = I_1 \cos^2 (\omega t) \cos^2 (90-\omega t) = I_1 \cos^2 (\omega t)[\cos (90) \cos (\omega t) - \sin (90) \sin (\omega t)]^2 = I_1 cos^2 (\omega t) (-sin^2 (\omega t)) $$
Oh, btw, I forgot to say that the light that strikes the first polarized is unpolarized. Will edit OP.
EDIT: Sorry, that latex line is long. Kind of ruins the forum template for me. Don't know how to make it so the equal signs are aligned in different lines..
DataGG said:
I did do that in paper, which I'll copy to latex above:
OK, except for a sign error.
Keep going.
Keep going.
Indeed, there is a sign error.
$$I_3 = I_1 cos^2 (\omega t) (sin^2 (\omega t)) = \frac{I_0}{2} \cos^2 (\omega t) [1-cos^2(\omega t)] = \frac{I_0}{2} [\frac{1}{2}(1+ \cos (2 \omega t)][1-\frac{1}{2}(1+ \cos (2 \omega t)] $$
Then comes
$$I_3= \frac{I_0}{4}(1+ \cos (2 \omega t)) (\frac{1}{2}(1- \cos (2 \omega t)) = \frac{I_0}{8} (1 - cos^2 (2 \omega t))$$
And now I'm not sure what to do.. Maybe expand the square? I'm not seeing anything..
EDIT: Actually, expanding the square might probably work. I'll then have another co-sin term squared, and If I do the substitution I used above, a 1/16 will appear and.. ya, let me try it on paper..
$$I_3 = I_1 cos^2 (\omega t) (sin^2 (\omega t)) = \frac{I_0}{2} \cos^2 (\omega t) [1-cos^2(\omega t)] = \frac{I_0}{2} [\frac{1}{2}(1- \cos (2 \omega t)][1-\frac{1}{2}(1- \cos (2 \omega t)] $$
Then comes
$$I_3= \frac{I_0}{4}(1- \cos (2 \omega t)) (\frac{1}{2}(1- \cos (2 \omega t)) = \frac{I_0}{8} (1 - cos (2 \omega t))^2 $$
You have another sign error: When you express ##\cos^2 \omega t## in terms of ##\cos 2\omega t##. Fix that and you're almost home.
I made a sign mistake there, again! Will correct asap
edit: damn, you were faster!
edit2: Fixed the mistake, I think.
Believe it or not, you still have a sign error. In your second line.
DataGG said:
humm
Consider the very last factor in your first line, which is correct. When you simplified that factor in the second line, you messed up a bit.
I'm an idiot! Alright, I now finally got it. Edited the post and below is the solution:
$$I_3 = \frac {I_0}{8}[1- \cos^2 (2 \omega t)] = \frac {I_0}{8} (1 - \frac {1}{2} - \frac {\cos (4 \omega t}{2})$$
and then finally,
$$I_3 = \frac {I_0}{16} (1- \cos (4 \omega t))$$
Thank you Doc Al!
and then finally,
Thank you Doc Al!
:thumbs: (And you are welcome!)
