Optimization problem with constraint
4 replies · 3K views
MarkFL
MHB
Here is the question:
CALCULUS needHELP WITH THIS PLEASE! APPRECIAT EIT -?
please DON'T GO AWAY WHEN YOU SEE THIS! HELP NEEDED THANKS
a 24 foot wire is cut into 12 pieces which are welded together to form a rectangular frame whose base is twice as long than it is wide .
the frame is than covered with paper to form a box . find the volume of the largest possible box that can be made this way
Please help with this thanks in advance so much
Here is a link to the question:
CALCULUS needHELP WITH THIS PLEASE! APPRECIAT EIT -? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Hello Zhina,
Let's let the dimensions of the box be $x,y,z$ (all positive) where the volume (the objective function) is:
$$V(x,y,z)=xyz$$
Each dimension will require 4 pieces of wire, so we have the constraint:
$$4x+4y+4z=4L$$ (where $4L$ is the total length of the wire)
$$g(x,y,z)=x+y+z-L=0$$
We also have the constraint (if we choose $y$ to be the length, and $x$ to be the width)
$$h(x,y,z)=y-2x=0$$
Using Lagrange multipliers, we obtain the system:
$$yz=\lambda-2\mu$$
$$xz=\lambda+\mu$$
$$xy=\lambda$$
which implies:
$$\lambda=yz+2\mu=xz-\mu=xy$$
$$yz+2\mu=xz-\mu$$
we obtain:
$$\mu=\frac{xz-yz}{3}$$
Now we also have:
$$xz-\mu=xy$$
$$\mu=xz-xy$$
and hence, we find:
$$\frac{xz-yz}{3}=xz-xy$$
$$xz-yz=3xz-3xy$$
$$-yz=2xz-3xy$$
$$x=\frac{yz}{3y-2z}$$
Substituting for $x$ into the second constraint, we find:
$$y=\frac{2yz}{3y-2z}$$
Since $y\ne0$, we may divide through by $y$ to obtain:
$$y=\frac{4z}{3}$$
Substituting for $y$ into the formula for $x$, we obtain:
$$x=\frac{\left(\frac{4z}{3} \right)z}{3\left(\frac{4z}{3} \right)-2z}=\frac{2z}{3}$$
Now, substituting for $x$ and $y$ into the first constraint, we obtain:
$$\frac{2z}{3}+\frac{4z}{3}+z=L$$
$$z=\frac{L}{3},\,y=\frac{4L}{9},\,x=\frac{2L}{9}$$
We know this is a maximum, as the other critical point is $$\left(0,0,4L \right)$$ giving:
$$V_{\min}=0\text{ ft}^3$$
Thus, we find:
$$V_{\max}=V\left(\frac{2L}{9},\frac{4L}{9},\frac{L}{3} \right)=3\left(\frac{2L}{9} \right)^3$$
Plugging in the given $$L=6\text{ ft}$$, we find:
$$V_{\max}=3\left(\frac{2(6\text{ ft})}{9} \right)^3=\frac{64}{9}\,\text{ ft}^3$$
To Zhina and any other guests viewing this topic, I invite and encourage you to post other optimization questions in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
This can actually be solved using single variable calculus. We know that the twelve pieces form the edges of a box, and we also know that we are making these pieces from a 24ft long wire. If we call the length "l", the width "w" and the height "h", then we have
[math]\displaystyle \begin{align*} 4l + 4w + 4h &= 24 \end{align*}[/math]
We are also told that the length is twice the width, so [math]\displaystyle \begin{align*} l = 2w \end{align*}[/math], and from there we can see that
[math]\displaystyle \begin{align*} 4 \left( 2w \right) + 4w + 4h &= 24 \\ 12w + 4h &= 24 \\ 4h &= 24 - 12w \\ h &= 6 - 3w \end{align*}[/math]
The volume of the box can be found using
[math]\displaystyle \begin{align*} V &= lwh \\ &= 2w \left( w \right) \left( 6 - 3w \right) \\ &= 12w^2 - 6w^3 \end{align*}[/math]
The maximum volume is where the derivative is 0, so
[math]\displaystyle \begin{align*} \frac{dV}{dw} &= 24w - 18w^2 \\ 0 &= 24w - 18w^2 \\ 0 &= 6w \left( 4 - 3w \right) \\ w = 0 \textrm{ or } w &= \frac{4}{3} \end{align*}[/math]
Clearly when w = 0, the volume will be 0, so the maximum volume has to be when [math]\displaystyle \begin{align*} w = \frac{4}{3} \end{align*}[/math]. To check that it's a maximum, we can check the value of the derivative on either side of the point (say at w = 1 and w = 2). So
[math]\displaystyle \begin{align*} \frac{dV}{dw} | _{w = 1} &= 6 \\ \\ \frac{dV}{dw} | _{w = 2} &= -24 \end{align*}[/math]
Since the gradients go from positive to 0 to negative, the criticial point is a maximum.
[math]\displaystyle \begin{align*} V &= 12 \left( \frac{4}{3} \right) ^2 - 6 \left( \frac{4}{3} \right) ^3 \\ &= 12 \left( \frac{16}{9} \right) - 6 \left( \frac{64}{27} \right) \\ &= \frac{64}{3} - \frac{128}{9} \\ &= \frac{64}{9} \end{align*}[/math]
Therefore the maximum volume is [math]\displaystyle \begin{align*} \frac{64}{9} \,\textrm{ft}\,^3 \end{align*}[/math], when the box has dimensions [math]\displaystyle \begin{align*} \frac{8}{3} \,\textrm{ft} \, \times \frac{4}{3} \,\textrm{ft} \, \times 2\,\textrm{ft} \end{align*}[/math].
Sorry Mark, it appears you've forgotten that the OP stated the length is twice as long as the width :)
Yes, thanks to your post, I realized I did not read the problem carefully enough, and I have edited my post to reflect the second constraint. I would not have used Lagrange multipliers if I had done so. :D
