Optimized Algorithm to Find All 720 Random Permutations of [0, 6)
The discussion revolves around finding an optimized algorithm to generate all 720 random permutations of integers in the range [0, 6). Participants explore various approaches, clarify definitions, and suggest different methods and algorithms related to permutation generation.
  • One participant presents an initial algorithm that generates 6 permutations but seeks an optimized version to produce all 720 permutations.
  • Another participant questions the definition of "optimized," asking whether it refers to execution speed, memory usage, or maintainability.
  • Some participants suggest using existing libraries or recursive and direct algorithms for generating permutations.
  • A participant shares a C language implementation for generating permutations, detailing a method to print different permutations through a function.
  • There is mention of Knuth's work and the Lehmer code as potential resources for generating permutations efficiently.
  • One participant clarifies the distinction between generating all permutations in a random order versus generating a sequence of random permutations with equal likelihood.
Participants express differing views on the best approach to generating permutations, with no consensus on a single optimal method. The discussion includes various suggestions and clarifications, indicating multiple competing perspectives.
Participants have not fully resolved the definitions of "optimized" or "random," which may affect the approaches discussed. Additionally, the scope of the problem may vary based on whether the goal is to generate all permutations or a sequence of random permutations.
Individuals interested in algorithm design, particularly in the context of permutations, as well as those looking for programming techniques in C or related languages.
intervoxel
TL;DR
Algorithm do find all random permutations of n=[0,6)
Summary: Algorithm do find all random permutations of n=[0,6)
Hi,
The following algorithm gives 6 out of the 720 random permutations of integers in the range [0, 6).
Code:
 t=0..5                             // permutation
        i=0..5                      // sequence index
            n = (t + i) % 6;        // % is the mod operator
            n = n*n % 11;           // 11 is prime
            n += n>>3;              // >> is the bit shift right operator
            n = n & 7;              // & is the bitwise AND operator
I need an optimized code that gives all the 720 random permutations:
Code:
    t=0..719                    // permutation
            n = f(t, i);
Thanks for any answer.
Technology news on Phys.org
Should move to computer forum.
What language are you using? or is that pseudo code in your example?
Optimised how, and why?
  • Least number of statements?
  • Lowest memory use?
  • Fastest execution?
  • Most random?
  • Most maintanable?
And what do you mean by random?
The easiest way to answer these questions is to write the code yourself (hint: generate all the 720 permutations and then sort the numbers 0..719 into a random order).
There are existing libraries that can do it, you can check how they do it.
There are recursive algorithms (given a permutation, find the next one e.g. when sorted like a lexicon) and direct algorithms (give me the nth permutation in this order).
Thank you for the kind answers, guys.
I found out exactly what I needed (c language):
[CODE title="Random permutations"]int idx = 6;
unsigned char permutation[] = { 0, 1, 2, 3, 4, 5 };
unsigned char temp[6];
void swap(unsigned char *a, unsigned char *b)
int t = *a;
*a = *b;
*b = t;
* Prints a different permutation.
void next()
while(true)
if(idx == 6)
int i;
for(i = 0; i < 6; i++)
temp = 0;
idx = 0;
if(temp[idx] < idx)
if(idx % 2 == 0)
swap(&permutation[0], &permutation[idx]);
else
swap(&permutation[temp[idx]], &permutation[idx]);
permutation[idx]++;
idx = 0;
printArray(permutation);
return;
else
temp[idx] = 0;
idx++;
}[/CODE]
Every time function next() is called, it prints a different permutation.
Can you point me at one of those?
Do you have Knuth vol 3? Or search for 'factoradic' or 'Lehmer code'. For only 6 elements this is not worth it of course.
It turns out that the OP's requirement was actually much simpler than it seemed from his OP.
I don't, and that was my first thought. :) But thanks, Lehmer code is exactly what I need.
Just to clarify, do you mean to determine all possible permutations and put them in a random order? If so, I would do it in exactly those two steps.
1) Make a methodical non-random list of all possible permutations.
2) Put that list into a random order.
On the other hand, suppose you want to generate a sequence of random permutations, with all permutations equally likely, and allowing repeats. The is an entirely different problem. But you can still make the list of step 1) above and repeatedly select one at random as long as you like.
  • · Replies 34 ·
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 25 ·
