The discussion revolves around the considerations for mounting SD and microSD connectors in PCB design, particularly focusing on the implications of soldermask coverage over vias and the choice between different connector types based on manufacturability and cost factors.
- Technical explanation
- Debate/contested
- Experimental/applied
- One participant inquires whether it is acceptable to mount an SD card connector with a metal frame over vias that are covered with soldermask.
- Another participant suggests consulting the assembly house for their "Manufacturability Guidelines," which address spacing and soldermask rules, while also mentioning potential issues like electromigration and noise coupling.
- A participant mentions finding an ALPS connector with standoffs that provide a 1.8mm separation from the board, indicating a preference for safer design practices.
- Another participant advises using Kapton tape for separation if producing a smaller quantity of boards, while suggesting moving the vias for larger production runs.
- A participant shares their decision to use a microSD connector due to lower cost, reduced board space requirements, and cheaper industrial-grade microSD cards compared to SD cards.
Participants express varying opinions on the best practices for mounting connectors and the implications of different design choices, indicating that multiple competing views remain without a clear consensus.
Considerations regarding manufacturability, cost, and design complexity are discussed, but specific assumptions about the effects of soldermask and connector choices remain unresolved.
PCB designers, engineers involved in electronics manufacturing, and those interested in optimizing connector choices for cost and space efficiency may find this discussion relevant.
