High School Where Did I Go Wrong in Calculating the Probability?
  • Thread starter Thread starter little neutrino
    Probabilities
The discussion focuses on calculating the probability of generating a code consisting of 3 letters and 2 digits, specifically finding the probability that exactly 2 letters are the same or 2 digits are the same, but not both. The user initially calculated the probabilities incorrectly, leading to a result of 0.210 instead of the correct answer of 0.197. Key mistakes included miscalculating the probability of exactly 2 letters being the same by not subtracting the case where all 3 letters are the same and misunderstanding the application of the exclusive or (XOR) probability formula.
  • Understanding of basic probability concepts
  • Familiarity with combinatorial counting methods
  • Knowledge of exclusive or (XOR) probability calculations
  • Experience with generating random codes and their structures
  • Learn about combinatorial probability in detail
  • Study the application of the XOR probability formula
  • Explore examples of generating random codes and calculating their probabilities
  • Investigate common pitfalls in probability calculations and how to avoid them
Mathematicians, statisticians, computer scientists, and anyone involved in probability theory or code generation who seeks to improve their understanding of probability calculations and combinatorial methods.
little neutrino
A code is generated consisting of 3 letters followed by 2 digits. Each of the 3 letters generated is equally likely to be any of the 26 letters of the alphabet. Each of the 2 digits generated is equally likely to be any of the nine digits 1-9. Find the probability that a randomly chosen code has exactly 2 letters the same or 2 digits the same, but not both.
Attempted solution:
P(exactly 2 digits same) = (263*9)/(263*92) = 1/9
P(exactly 2 letters same) = (26*25*3*92)/(263*92) = 75/676
P(2 digits same AND 2 letters same) = (26*25*3*9)/(263*92) = 25/2028
Required probability = 1/9 + 75/676 - 25/2028 = 0.210
But the correct answer is 0.197. Can I ask where did I go wrong? I can't figure it out...
Thanks!
Attempted solution:
Thanks!
Your calculation for 2 letters is the probability that at LEAST 2 letters is the same. You have to subtract off the probability that all 3 letters are the same to get the probability that exactly 2 letters are the same.
One other possible mistake. Exactly how many ways are there to have 2 items the same in a set of 3?
But why is that so?
__ __ __ __ __
For two letters to be the same == 26 choices
For the last letter, since it can't be the same as the two letters that are the same == 26 - 1 = 25 choices
No. of ways to arrange 3 letters, when 2 are the same == 3!/2! = 3
Thus no. of ways == 26 * 25 * 3 * 92
Why did I calculate the probability that at least 2 letters are the same? Could you elaborate? Sorry kind of confused.
Yup I'm dumb sorry :D
Hmm. My criticism was mistaken, but here's a suggestion: Instead of computing probabilities for the various possibilities, try just computing
N_L = the number of ways to have exactly 2 letters the same, and both digits different.
N_D = the number of ways to have 3 or 0 letters the same, and both digits the same.
Then the probability is \frac{N_L + N_D}{26^3 \cdot 9^3}
When I did it that way, I got the expected answer.
Okay, I figured out what you did wrong:
You used P(A \vee B) = P(A) + P(B) - P(A \wedge B) where A = "exactly 2 letters the same" and B = "both digits the same". But they aren't asking for A \vee B, they're asking for A\ xor\ B (xor = exclusive or). The formula for that is:
P(A\ xor\ B) = P(A) + P(B) - 2P(A \wedge B)
10K
