Orangescrum not installing in Centos 7?
  • Thread starter Thread starter Brief-Wishbone
    apache installation
6 replies · 2K views
Brief-Wishbone
TL;DR
The official tutorial for automated installation of centos 7 doesn't work. So, I had to refer to online tutorials.
I installed apache 2.4,php 7.2, mysql 5.7.
Then I downloaded .zip source code from here
https://github.com/Orangescrum/orangescrum.
Then, I setup some permissions and ownership as per documentation.
Code:
    $ sudo mv ~/orangescrum-main /var/www/html && sudo chown root:root -R /var/www/html
    $ sudo chmod -R 0777 /var/www/html/orangescrum-main/{app/Config,app/tmp,app/webroot}
Then I setup a virtual host orangescrum.conf in /etc/httpd/conf.d.
Code:
  <VirtualHost *:80>
    ServerName orangescrum.example.com
    DocumentRoot /var/www/html/orangescrum-main
    <Directory /var/www/html/orangescrum-main>
    Options Indexes FollowSymLinks MultiViews
    AllowOverride All
    Order allow,deny
    allow from all
    </Directory>
    </VirtualHost>
Then I created mysql database
Code:
  CREATE DATABASE orangescrum;
    CREATE USER 'orangescrumuser'@'localhost' IDENTIFIED BY 'yourpassword';
    GRANT ALL PRIVILEGES ON orangescrum.* TO 'orangescrumuser'@'localhost' IDENTIFIED BY 'yourpassword' WITH GRANT OPTION;
    FLUSH PRIVILEGES;
    EXIT;
Then I imported the database.
Code:
    $ mysql -u root -p orangescrum < /var/www/html/orangescrum-main/database.sql
Then I updated orangescrum credentials inside `/var/www/html/orangescrum-1.6.1/app/Config/database.php`
Code:
 'login' => 'orangescrumuser',
    'password' => 'yourpassword',
    'database' => 'orangescrum',
But it's not working and I'm getting the below output when I enter my ip address in browser.How do I fix this issue? Is there a way?
http://i.stack.imgur.com/7FQg1.png
I wouldn't call this as an "issue", you just haven't configured Apache to serve PHP files. There are better places to learn how to do this stuff than PhysicsForums.
Any suggestions for places?
I've tried all tutorials at least five times. None of them work.
Have you fixed this?
If so, how do you know?
If not, how much progress do you think you are going to make?
Is your Apache server configured to load index.php file by default? (I'm assuming this is the file you have in your /app/webroot/ folder.)
See the DirectoryIndex directive for more info.
Just adding this filename to your request should also work.
