Orbital Angular Momentum and Photon Energy
The discussion centers on the relationship between orbital angular momentum (OAM) and photon energy, specifically addressing the equation E² = p²c² + m²c⁴. Participants clarify that OAM is not included in the p²c² term, as the energy-momentum relation for photons is defined by E = pc = ħkc, where m = 0. The conversation emphasizes that while total angular momentum has physical significance, the separation of orbital and spin angular momentum lacks a gauge-invariant definition. The discussion concludes that energy can potentially be expressed in terms of angular momentum, paralleling concepts in Newtonian physics.
  • Understanding of quantum mechanics and photon properties
  • Familiarity with the energy-momentum relation E = pc = ħkc
  • Knowledge of angular momentum concepts in quantum physics
  • Basic grasp of gauge invariance and its implications in physics
  • Research the role of angular momentum in quantum mechanics
  • Explore the Belinfante energy-momentum tensor and its applications
  • Study the relationship between photon polarization states and angular momentum
  • Investigate the mathematical formulation of angular momentum four-vectors
Physicists, quantum mechanics students, and researchers interested in the interplay between angular momentum and photon energy in quantum field theory.
jkg0
Just a quick question on photon orbital angular momentum.
In the equation for photon energy: E2 = p2c2 + m2c4
Is OAM counted in the p2c2 part? Or does the above equation only apply to photons with normal momentum and there is another term for the angular momentum?
The normal relation for p seems to be p = kħ but isn't k just a vector?
The energy momentum relation for a photon is, E=pc=\hbar k c since m=0.
If you really want to talk about OAM for a single photon, you will have to specify it's quantum state. Now, you can represent the state of a photon as an infinite sum over all possible momenta (i.e., plane waves, each with a different momentum \hbar \vec{k}), but you can also represent the state of a photon as an infinite sum over all possible values of angular momentum L=m\hbar. The best you can do in finding the angular momentum of a photon is knowing the probabilities of measuring any particular value of the angular momentum, or measuring the average value from that distribution.
Wikipedia has a decent coverage of this.
The problem I am having is that the energy for a single photon is defined by E=pc=\hbar k c with the k vector.
If the quantum state of the photon can also be written as the integration of L=m\hbar over varying probabilities is there a way to write the energy momentum relationship with respect to the m values of angular momentum instead of the k vector?
There's no sensible notion of a photon's orbital and spin angular momentum, because there's no gauge invariant definition of this splitting. Only total angular momentum has a physical meaning in this case.
I would say there is a meaningful decomposition of orbital and spin angular momentum, though the exact values depend on your reference frame.
The spin-angular momentum is given by a photon's polarization state,
while the orbital angular momentum is obtained from its linear momentum.
As far as expressing the energy-momentum relation in terms of angular momentum, I don't know that the four-vector for angular momentum would be.
The energy-momentum relation comes from the conservation of the "length" of the momentum four-vector.
p^{\mu}p_{\mu} = \frac{E^{2}}{c^{2}}-p^{2} =\frac{E'^{2}}{c^{2}}=m^{2}c^{2}
Rearranged, this gives
E^{2} = p^{2}c^{2}+m^{2}c^{4}
which looks more familiar (where again for a photon m=0.
Unfortunately, I don't know what the angular-momentum four-vector would be, but I expect it must be possible to represent energy in terms of angular momentum just as it is in Newtonian physics
Exactly! No only you don't know what the angular-momentum four-vector would be but nobody else. Only total angular momentum is a gauge invariant quantity and defined via the corresponding Belinfante energy-momentum tensor components. Written in 3D-form it reads
$$\vec{J} = \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} \vec{x} \times (\vec{E} \times \vec{B}).$$
A basis for the polarization states of the photon are the helicity ##\eta=\pm 1## states. These are the dual and self-dual parts of the Faraday (fielt-strength) tensor or in terms of classical optics the right- and left-circular polarized modes of the electromagnetic field.
I think it is important to note that angular momentum eigenstates (vector spherical harmonics) can be constructed from momentum eigenstates with the same absolute value k but different direction. Hence the relation between E and k remains valid.
  • · Replies 42 ·
  • · Replies 28 ·
