Orbital periods in binary and trinary star systems
6 replies · 4K views · last reply
Exy
TL;DR
Given a stable 2 or 3 body system with each object having different masses and circular orbits around the barycenter, how do I calculate each bodies orbital period?
Hello physics,
While this is about sci-fi worldbuilding, I feel like this belongs on this board more.
CONTEXT:
I have been building a fictional neighborhood for our star and using the formula
Equation T = 2π√(a³ / (G(m1 + m2))) showing orbital period T in terms of semi-major axis a, gravitational constant G, and masses m1 and m2.
to get the orbital period of orbiting bodies around a stationary mass. Some of the systems have been decided by RNG to be binary and trinary starsystems however, and now I am researching the 2 and 3 body problems.
The actual problem (more of a thought experiment) goes as follows:
2 bodies with the masses m1 and m2 with m1 ≠ m2. With both orbiting the barycenter in circular orbits, the above formula does not give usable results.
The question is now either how to get the orbital period of each body, or how to get the relation between the radii of each objects orbit based on their mass (and any other needed parameters)
Two schematic diagrams of circular orbits: left, a small inner orbit and a larger outer orbit with bodies labeled m1 and m2, caption m1>m2; right, three concentric orbits with bodies m1, m2 and m3, caption m3>m2>m1.
Then the question turns to stable 3 body systems with each orbiting the joint center in a circle. The goal here again are each bodies orbital period with circular orbits, leading to a stable system. Each body may again have different masses
One of the systems features a large star in the center with 2 smaller ones orbiting it on directly opposite sides. I used the above formula for this with the 3rd stars mass simply being counted as belonging to the stationary center, but is this correct? I would imagine this to be dubious, but I simply do not know.
What I do unterstand is that these systems are incredibly unstable in reality, but this is just 2 or 3 bodies of different masses orbiting a joint center without being perturbed or losing energy. My current understanding tells me that the 3 body system would need 2 of the bodies to have identical mass, but maybe they don't.
I have looked around the Internet, but have not found anything that I could use. This seems to be a massive rabbithole.
Maybe someone here knows where to go or how to solve this.
EDIT: I have found the answer for the 2 body problem within the wikipedia page for "Barycenter" regarding the distances, but not the orbital period.
Astronomy news on Phys.org
Is the solar system which consists of the sun and planets an answer to your question ?
No I don't think so. I may not have been very good at explaining the problem.
Imagine the 3 body problem with identical masses, all orbiting their barycenter in a circle.
The question is what each bodies distance to the center would be if they were different in mass, but all still orbiting in a circle, now of course at different orbital radii. So a non-hierarchical system.
I have attempted to translate the principles of the binary system over, where a mass 5 times heavier than the other would be five times as close to their shared center, but have had no luck so far.
(3,3) figure in
https://en.m.wikipedia.org/wiki/File:5_4_800_36_downscaled.gif seems to be your case. I am not sure whether we can extend this pattern to different masses cases or not.
Tl;dr: Here is as far as I have gotten in my failures, but my stomach has now also given up and I cannot work on this until that's fixed. We will see how well I can keep up.
I have been trying to do this since but have not managed to get it to work. I tried to treat it as a 2 body problem with the barycenter of the opposing bodies as the second mass, then placing the masses in such a way as to make their relative distances appropriate at a separation of 120° around the rotational center, but I have not managed to make this work
Hand-drawn diagram of three masses m1, m2 and m3 at the vertices of an equilateral triangle, with barycenter labels bary (m2;m3), bary (m1;m3) and bary (m2;m3) at the midpoints of the sides, a 120° angle marked at the centre, and an arrow indicating rotation.
Now it might be that I just didn't manage to do it, but
http://www.scholarpedia.org/article/Three_body_problem (homographic solutions, figure 3)
Diagram of three bodies in a relative equilibrium: a large red dot, a blue dot and a small black dot on concentric circular orbits around a common centre, with labelled axes ranging from -2 to 2.
Shows an animation of 3 bodies in equilibrium, basically as needed. The interesting thing here is that they seem to be in formation as an equilateral triangle (so with the 120° separation), BUT they are rotating around some other point. So I tried having them orbit their shared barycenter:
Geometric construction on coordinate axes: a circle with an inscribed triangle D, E, B and a horizontal chord DE through H, with lines from D, E and B meeting at point G near the origin, plus points I, J, A and labels h and i.
But I have also not been able to get this to work. Maybe some other center is needed or I am just not calculating the orbital periods correctly, since they are not coming out as equal.
AND THEN my stomach decided to get an infection and now I can barely write this post. It will take probably at least 1-2 weeks before I can investigate this further. I will try to keep up with this tread, but we will see.
Here it seems that the third body is on a Lagrange point.
Diagram of three concentric circular orbital paths centered on the origin of a coordinate plane, with a large red dot, a medium blue dot and a small black dot each on a separate orbit.
(animation by R. Moeckel).
Yes, Lagrange showed that this must be the case (I have replaced the image you posted with the animated version).
Exy said:
BUT they are rotating around some other point [than their barycentre]
What makes you think that? Newton's first law requires that they can only orbit the barycentre, and this is how they are depicted (note that ## m_{\text{red}} > m_{\text{blue}} \gg m_{\text{black}} ##).
