Order preserved Lotto distribution
  • Thread starter Thread starter Cylab
    Distribution
The discussion focuses on calculating the probability of matching four numbers in a Lotto game where the order of selection is preserved. Participants clarify that while the hypergeometric distribution can compute probabilities for unordered selections, the challenge lies in defining the probability distribution for ordered samples. It is established that if an unordered sample is sorted, the probability of matching remains consistent with the unordered case, as the same set of numbers is used.
  • Understanding of hypergeometric distribution
  • Knowledge of probability theory
  • Familiarity with ordered and unordered samples
  • Basic concepts of Lotto number selection
  • Research the properties of hypergeometric distribution in detail
  • Explore probability distributions for ordered samples
  • Learn about sorting algorithms and their impact on probability calculations
  • Investigate Lotto game strategies and their mathematical foundations
Mathematicians, statisticians, game theorists, and anyone interested in probability calculations related to Lotto games.
Cylab
42 balls are numbered 1-42. You select six numbers between 1 and 42. (The ones you write on your lotto card). I know if it is randomly selected regardless of order, it is easy to compute probability that they contain some numbers of yours, E.g. P(Match 4), by hypergeometric Distribution. BUT, NOW, the point is what is probability of matching 4 numbers, given that order is preserved? E.g. If we write 10 at first next number must be more than 10 (can`t write 9 after 10).
Thanks in advance for your attention. Please be advised it is Not homework.
I don't fully understand the question. If you picked a 42 first then you would blow up? There seems to be inconsistencies in the question.
So much here depends on how you choose to define the probability distribution over ordered samples; that is: to say what you mean by a random ordered sample. One way would be to take an unordered sample, then sort it, but there are other methods as well. In the case of sorting an unordered sample the probability of getting a match would be the same as in the unordered case, because the same set of numbers would be involved.
RGV
