Orthonormal Basis times a real Matrix
6 replies · 2K views · last reply
linearishard
Hi!
I have an orthonormal basis for vector space $V$, $\{u_1, u_2, ..., u_n\}$. If $(v_1, v_2, ..., v_n) = (u_1, u_2, ... u_n)A$ where $A$ is a real $n\times n$ matrix, how do I prove that $(v_1, v_2, ... v_n)$ is an orthonormal basis if and only if $A$ is an orthogonal matrix?
Thanks!
Could you explain how $(u_1, u_2, \ldots, u_n)A$ is defined? I don't understand, since the $u_j$ are vectors in an arbitrary $n$-dimensional (real) vector space, while $A$ is an $n \times n$ matrix.
Do you mean to write $v_j = Au_j$ where $A$ is an endomorphism of a real inner product space $V$ and then prove that the $v_j$ form an orthonormal basis iff $A$ is an orthogonal transformation?
Hi linearishard,
First suppose $A$ is orthogonal. Then $A^TA = I$, so for all $i,j\in \{1,2,\ldots, n\}$, $$\langle Au_i, Au_j\rangle = \langle A^TAu_i, u_j\rangle =\langle Iu_i, u_j\rangle = \langle u_i, u_j\rangle = \delta_{ij}$$ where the last equality follows from orthonormality of $\{u_1,\ldots, u_n\}$. Therefore, $\{v_1,\ldots, v_n\}$ is an orthonormal set. The set $\{v_1,\ldots, v_n\}$ is also linearly independent, for if $$\sum_{i = 1}^n c_i v_i = 0$$ is a linear dependence relation, then $$A\left(\sum_{i = 1}^n c_i u_i\right) = 0$$ Pre-multiplying both sides of the equation by $A^T$ and using the fact $A^TA = I$, one receives $$\sum_{i = 1}^n c_i u_i = 0$$ whence $c_1 = \cdots = c_n = 0$ by linear independence of $\{u_1,\ldots, u_n\}$. Thus, $\{v_1,\ldots, v_n\}$ is a basis for $V$.
Conversely, suppose $\{v_1,\ldots, v_n\}$ an orthonormal basis. For all indices $i$ and $j$, $\langle Au_i, Au_j\rangle = \delta_{ij}$. So since $\{u_1,\ldots, u_n\}$ is an orthonormal basis then for every $i$ $$A^T Au_i = \sum_{j = 1}^n \langle A^T A u_i, u_j\rangle u_j = \sum_{j = 1}^n \langle Au_i, Au_j\rangle u_j = \sum_{j = 1}^n \delta_{ij}u_j = u_i$$ Consequently $A^TA = I$, i.e., $A$ is orthogonal. $\blacksquare$
Thank you for your response, could you please explain to me the logic behind the last line? How do you go from <ATAui,uj> to <Aui,Auj>?
Since $A^T$ is the adjoint of $A$, $\langle A^Tx,y\rangle = \langle x, Ay\rangle$ for all $x,y\in V$. In particular, the equality holds when $x = Au_i$ and $y = u_j$.
Since we're apparently working with real numbers, we can write:
$$\langle A^Tx,y\rangle
= (A^Tx)^T \cdot y
= (x^TA)\cdot y
=x^T\cdot (Ay)
=\langle x, Ay\rangle
This is generally true for the dot product of vectors with real numbers.
For complex numbers the same thing holds, just with the conjugate transpose or adjoint (usually written as $A^\dagger$, $A^*$, or $A^H$) instead of the transpose $A^T$.
