P-Series or Comparison Test Question
6 replies · 2K views · last reply
RJLiberator
K≥0 ∑ ((sqrt(k)+2)/(k+5))
I am trying to prove that this diverges. The divergence test is inconclusive.
Now I am left with a great option of a comparison test. I'm not quite sure what to compare it with, but I know I need to compare it with something smaller (denominator is larger) that diverges to prove divergence.
While looking at it, I am wondering if this is as simple as using the p-series test and taking off the smaller quantities of 2 and 5 and just using k^(1/2)/k where p would then = 1/2 and prove divergence.
Can I do this with the p-series?
IF not, I need to find something that is in comparison with this to prove divergence. Would k^(1/2)/2k be ok to use?
This last line of reasoning is good. You care about what the terms do as k gets large, so looking at the dominant terms in the numerator and denominator is a good idea.
For large k, the series looks like ##k^{-1/2}##, so using the limit comparison test with ##k^{-1/2}## might work.
You could also make an argument that the terms of the series are larger than a series of the form ##c/\sqrt{k}## and use the direct comparison test.
You can't say it's a p-series because it's not of the form ##1/k^p##.
You could also make an argument that the terms of the series are larger than a series of the form ##c/\sqrt{k}## and use the direct comparison test.You can't say it's a p-series because it's not of the form ##1/k^p##.
Thank you for your help
1) Ah, I cannot say it is a p-series because it is not in correct form. Great information.
2) Limit comparison test seems like a great idea, I may not be able to use it since we will be learning that later in the course.
3) I will need to use the direct comparison test that you pointed out to me. I am going to try this work now.
Thanks.
Since the sum starts at a value of 0 I cannot use k^(-1/2) alone in the denominator.
Can I compare it with c/(sqrt(k+1)) ?
It would be simpler to throw away the first term. In other words, if the sum from k=1 converges, then the sum from k=0 will converge as well because the two series only differ by a finite number of terms.
The reason a series of the form ##c/\sqrt{k}## is nice to have is because it is a p-series, and you can therefore conclude it diverges.
Ah... That makes sense. Being able to throw away initial 0 as it doesn't really add anything to the convergence/divergence of the sum. Thank you.
You tell us. You need to have some confidence in your own knowledge/abilities.
