Parallel LCR resonant frequency derivation for larger resistances
The discussion revolves around deriving an expression for the resonant frequency of a parallel LCR circuit, particularly focusing on scenarios with larger resistances. The original poster expresses difficulty in aligning their derived expression with experimental data, suggesting potential errors in their approach.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of Kirchhoff's law and the use of complex numbers in solving the differential equation. There is a mention of conditions for oscillation and the implications of damping in the system.
The conversation includes various interpretations of the problem, with some participants agreeing on the validity of the original poster's approach while others suggest alternative methods for deriving the resonant frequency. There is an ongoing exploration of the implications of the assumptions made in the derivation.
Participants note the importance of ensuring that certain conditions, such as 1/LC > R2/4L2, are met to avoid overdamping in the system. The original poster's experimental data is also mentioned as a potential source of discrepancy.
QuarterWit
[SOLVED] Parallel LCR resonant frequency derivation for larger resistances
There have been similar questions here before which I have seen, but I couldn't find an answer with the detail I require.
I would like to derive an expression for the resonant frequency of a parallel LCR circuit with a large (not negligible) resistance.
I have seen a https://www.physicsforums.com/showthread.php?t=121069" of a solution (the same as mine but with the "4" omitted) but it doesn't fit my experimental data by a long shot, though my data could be wrong. The solution I came up with is a lot closer to my data but that doesn't necessarily mean it's right, could someone check through and explain if/where I've gone wrong
http://gray.slightlybeanish.com/Other/LCR.jpg
http://gray.slightlybeanish.com/Other/LCRDerivation.jpg
I mostly suspect the first step is wrong, I was trying to apply Kirchoff's law
QuarterWit said:
... an expression for the resonant frequency of ...
I[/URL] agree with this. You just have to make sure that 1/LC > R2/4L2 (otherwise the system is overdamped).
Kirchoof is never wrong. What you have done is right. If you want to get the solution of the equation by the help of complex numbers. However that is unnecessary
Thanks for replying so quickly, I'm glad you agree.
Fedex: I'm not sure whether you mean your 3rd sentence to be connected to the 2nd or the 4th. Anyway, I have used complex numbers, which is why the arguments under the square root changed signs.
As turin said, I'd assumed 1/LC > R2/4L2. Which would give a complex solution to the quadratic, leading to an oscillating solution to the differential equation, with the angular frequency stated.
For any other readers, this can also be solved by calculating the impedance directly and finding when it's a maximum, I was just looking for a short derivation.
My mistake. What i wanted to say is that we can solve the second order differential equation with the help of complex numbers. But that is quite long.
Ah ok, that is what I did, I wasn't aware there was another way to do it, I just omitted it from the working because it's the same for any question.
The method is shown http://tutorial.math.lamar.edu/Classes/DE/ComplexRoots.aspx" for those wondering how I suddenly leapt to the frequency from the characteristic equation. I just realized that if the system is to oscillate, the roots will be complex, so the trial solution will have a decay term e-R/2L multiplied by (Acosωt + Bsinωt)
(ω as above)
I thought that was the short derivation. That's how I did it. I just found the poles of the transfer function in extended Fourier space. It is just a few lines of algebra (depending on how much detail you want to show).
10K
