Parametric Derivatives and Normal Equations for a Curve with Gradient 1
9 replies · 2K views
sooyong94
The parametric equations of a curve are
##x=\frac{1}{2}(sint cost+ t), y=\frac{1}{2} t-\frac{1}{4} sin2t##,
##-\pi/2<t\leq0##. P is a point on the curve such that the gradient at P is 1. Find the equation of the normal at P. Hence, determine if the normal at P meets the curve again.
Parametric differentiation, chain rule
I have found ##\frac{dy}{dt}## and ##\frac{dt}{dx}##. ..Then ##\frac{dy}{dx}=\frac{1-cos 2t}{1+cos2t}##
I have also found out that when ##\frac{dy}{dx}=1##, ##t=\frac{-\pi}{4}##. Then the equation of the normal is ##y=-x-\frac{\pi}{4}##. Now I don't know how to determine if the normal at P meets the curve again... :confused:
hi sooyong94! :smile:
hint: what is x + y ? :wink:
Yes, using the fact that sin(2t)= 2sin(t)cos(t), adding the parametric equations for x and y gives x+ y= t.
But [itex]y= -x- \frac{\pi}{4}[/itex] tells you that [itex]x+ y= \frac{\pi}{4}[/itex]. Wherever the curve and line intersect, they must both be true.
But ##y= -x- \frac{\pi}{4}## tells you that ##x+ y= \frac{\pi}{4}##. Wherever the curve and line intersect, they must both be true.
But that's ##t=\frac{\pi){4}##, which is not within the domain of t. :/
no, its -π/4
:hmm: Wasn't there should another coordinate that intersects with the curve other than x=-pi/4?
I mean the normal line cuts the curve at other points... is it possible for that? :confused:
