Parametric equations for the plane z=2
ainster31
I'm quite rusty in Linear Algebra.
If you have a plane in 3D with the equation ##z=2##, what does ##x## and ##y## equal? Does ##x=t## and ##y=t##?
Because if I graph that in Wolfram Alpha, I don't get a horizontal plane in 3D at ##z=2##: http://www.wolframalpha.com/input/?i=graph+z=2,x=t,y=t
hi ainster31! :smile:
line: one parameter
plane: two parameters :wink:
your plane is z = 2, x = t, y = u​
tiny-tim said:
hi ainster31! :smile:line: one parameter
Hmm... what about 3 parameters? What would that result in? A filled 3D cube, right?
3 dimensions: 3 parameters …
n dimensions: n parameters …
that's very nearly a definition of dimensions! :smile:​
z=2 is the equation of a plane in R^3. x and y range over R since they are not specified. So you essentially end up with an x,y plane. In wolfram alpha they just show a line since there doesn't appear to be an easy way to tell it you want R^3. Your initial assumption was correct and variable t shouldn't be introduced.
