Parametric hypothesis, uniform distribution
1 reply · 2K views
Deimantas
We are given a sample of size 100. After some tests (histogram, Kolmogorov) we deduce the sample X is distributed uniformly. The next task is to presume the parameters are equal to values of your choice, and test if such hypothesis is true.
Uniform distribution has two parameters, a and b. My estimated parameters are a=1.01 (minimum value in the sample) and b=3 (max value in the sample).
I'm testing null hypothesis: b=3. The value of parameter a is known (1.01).
Mn= ((Xmax-b)*100)/(b-a) = 0
The percentiles are calculated using this formula:
hp=ln(p). So
h0.025=ln(0.025)=-3.6888794541139363
h0.975=ln(0.975)=-0.0253178079842899
The value of Mn should fall in the interval between h0.975 and h0.025 for the hypothesis to be accepted as correct.
This must be wrong, because I chose b value that is equal to the max value of the sample X, which should be a good estimate, and so the hypothesis should be accepted. What am I missing?
I think I might have got it. The reason values like 2.99 or 2.999 won't work is because b value is the maximum, and we already have a maximum of 3 in our sample of 100 elements. So the real value of parameter b can't be smaller than the one we already have in our sample, only equal or larger. I calculated, using the confidence interval formulas, that the real value of b should be in the interval of 3.001 and 3.076. It's because there might be larger elements in the general sample. Kinda makes sense, though it's a pity my estimated parameter b value of 3 doesn't fall in the interval and has to be rejected..
