How to Prove the Partial Fraction Formula for Distinct Complex Numbers?
The discussion centers on proving the partial fraction formula for distinct complex numbers, specifically the equation ∏_{n=1}^N (1/(z - z_n)) = ∑_{n=1}^N (α_n/(z - z_n)) for distinct complex numbers z_1, z_2, ..., z_N. The coefficients α_n are defined as α_n = ∏_{n'≠n} (1/(z_n - z_{n'})). A proof by induction is suggested, starting with the base case of N=1 and extending to N+1. The author emphasizes the uniqueness and existence of the coefficients α_n through separate techniques, asserting that their proof style is superior.
  • Understanding of complex numbers and their properties
  • Familiarity with mathematical induction
  • Knowledge of partial fraction decomposition
  • Ability to manipulate algebraic expressions involving complex variables
  • Study the principles of mathematical induction in depth
  • Explore advanced topics in complex analysis, particularly partial fraction decomposition
  • Investigate the uniqueness of coefficients in polynomial interpolation
  • Review proofs involving complex functions and their properties
Mathematicians, students studying complex analysis, and anyone interested in advanced algebraic techniques and proofs related to partial fractions.
jostpuur
I have figured out a nice way to prove that if the complex numbers z_1,z_2,\ldots, z_N\in\mathbb{C} are all distinct, then the equation
<br /> \prod_{n=1}^N \frac{1}{z - z_n} = \sum_{n=1}^N \frac{\alpha_n}{z-z_n}<br />
is true for all z\in\mathbb{C}\setminus\{z_1,z_2,\ldots, z_N\}, where the alpha coefficients have been defined by the formula
<br /> \alpha_n = \underset{n&#039;\neq n}{\prod_{n&#039;=1}^N} \frac{1}{z_n - z_{n&#039;}}<br />
I would like to leave the proof of this result as challenge to you guys, and I'm not in a need for advice myself at this point. Of course if somebody proves this in a way that is different from my proof, then I'm still reading.
[ SPOILER="spoiler" ]
There might be a simpler way, but you can prove it by induction. The base case is N=1. Then we need to show that
\Pi_{n=1}^1 \frac{1}{z-z_n} = \sum_{n=1}^1 \frac{\alpha_n}{z-z_n}
That's pretty obvious. Now, suppose it is true for N. Then we have:
\Pi_{n=1}^N \frac{1}{z-z_n} = \sum_{n=1}^N \frac{\alpha_n}{z-z_n}
Now, multiply both sides by \frac{1}{z-z_{N+1}}. On the left side, we have:
\Pi_{n=1}^{N+1} \frac{1}{z-z_n}
On the right side, we have:
\sum_{n=1}^N \frac{\alpha_n}{z-z_n} \frac{1}{z-z_{N+1}}
Now, we use the fact that:
\frac{1}{z-z_n} - \frac{1}{z-z_{N+1}} = \frac{z_n -z_{N+1}}{(z-z_n) (z-z_{N+1})}
So \frac{1}{z_n - z_{N+1}} [\frac{1}{z-z_n} - \frac{1}{z-z_{N+1}}]= \frac{1}{(z-z_n) (z-z_{N+1})}
So we can rewrite the right-hand side as
\sum_{n=1}^N \frac{\alpha_n}{z_n - z_{N+1}} [\frac{1}{z-z_n} - \frac{1}{z-z_{N+1}}]
= [\sum_{n=1}^N \frac{\bar{\alpha_n}}{z - z_n}] + \frac{\bar{\alpha_{N+1}}}{z-z_{N-1}}
where \bar{\alpha_n} = \frac{\alpha_n}{z_n - z_{N+1}} and where \bar{\alpha_{N+1}} = \sum_{n=1}^N -\frac{\alpha_n}{z_n - z_{N+1}}
So we can write the right-hand side as \sum_{n=1}^{N+1} \frac{\bar{\alpha_n}}{z - z_n}
So the only thing left is to prove that \bar{\alpha_n} has the right form, which is beyond what I have the energy for right now.
[ /SPOILER ]
A month has passed since the opening post, so I'll give a hint. My own proof splits into two independent parts, where we use one technique to prove that if the formula is true with at least some alphas, then the alphas cannot be anything else but the ones given by the claim. Then we use another technique to prove that the formula is true with at least some alphas. In other words my proof proves the uniqueness and existence of alpha coefficients separately, which is typical in mathematics.
Although the work of stevendaryl was left incomplete, actually the induction step found by him does provide a proof for the existence of the alphas, so in this sense half of the problem already got solved. Anyway, I can assure you that my proof for the existence does not use induction, and consequently in my opinion has more style to it. I cannot insist that my existence proof would be shorter though; looks roughly the same in terms of length.
