Integral of 2/(2x-3) using partial fractions
16 replies · 5K views
Ry122
Problem: Find the integral of 2dx/(2x-3) using partial fraction decomposition
Attempt:
A/(2x-3)
Compare coefficients A = 2
[tex]2 \int (1/(2x-3)) = 2ln(2x-3)[/tex]
This is wrong. Can someone please tell me what I'm doing wrong?
Use u-substitution. Let u=2x-3.
Attempt:
A/(2x-3)
you don't need partial fractions for this.
just put u=2x-3 and go from there
This is just a simple problem that I want to apply the technique to and further my understanding of it so that I can begin using it on more difficult questions.
Did the problem tell you that you must use partial fraction for this problem? Because in my opinion, it makes no sense to use it.
Also, [tex]\int \frac{1}{2x-3} \neq ln(2x-3)+C[/tex] therefore [tex]2 \int \frac{1}{2x-3} \neq 2ln(2x-3)+C[/tex]
well in a sense...when you have a linear factor in the denominator like 2x-3, in the question, it kinda already is a partial fraction.
The integral of 1/x is lnx + c
So then shouldn't the integral of
1/2x-3 be ln(2x-3) + c
If not then what is it?
And yes the question did ask me to use partial fractions for this problem.
Integrals of the form a+bu
[tex]\int \frac{1}{a+bu}du=\frac{1}{b}ln|a+bu|+C[/tex]
To check that this is false: if you take the derivative with respect to x of "ln(2x-3) + c", it will not equal [tex]\frac{1}{2x-3}[/tex] since you have to use the chain rule.
[tex]\int \frac{1}{2x-3} dx[/tex]
if u=2x-3, then [itex]\frac{du}{dx}=2 \Rightarrow \frac{du}{2}=dx[/itex]
now just put that into the integral
Can partial fraction decomposition even be used in this situation to get a correct answer?
The partial fraction decomposition of 1/(2x-3) IS 1/(2x-3). Please believe what people are telling you.
How would i do this one:
integral of ((x^2)+1)/(6x-9x^2)
The highest degree of the denominator is equal to the highest degree of the numerator but it has to be greater than it.
Do polynomial long division first, to make sure the degree of the denominator is greater than that of the denominator.
Have no idea how to do that. Can you please show me?
What, you mean how to divide?
Well, see if you can follow this:
[tex]\frac{x^2 +1}{6x-9x^2} = \frac{-1}{9}\left( \frac{9x^2+9}{9x^2 - 6x} \right)<br /> <br /> = \frac{-1}{9}\left( \frac{9x^2 -6x + 6x +9}{9x^2 - 6x} \right)<br /> <br /> = \frac{-1}{9}\left( 1 + \frac{6x+9}{9x^2 - 6x} \right)<br /> <br /> = \frac{-1}{9}\left( 1+ \frac{2x+3}{3x^2 - 2x} \right)[/tex].
How about now?
i understand but why did the sign of only the denominator change in the 1st step and not the numerator?
Edit: nevermind, figured it out.
THanks for your help everyone
http://www.imagehuge.com/images/a7ttelgdzf3crvdsouk.jpg
