Partial Order/Upper Bound Proof from How to Prove It
10 replies · 4K views · last reply
zooxanthellae
Partial Order/Upper Bound Proof from "How to Prove It"
Suppose R is a partial order on A and B is a subset of A. Let U be the set of all upper bounds for B. Prove that U is closed upward; that is, prove that if x E U and xRy then y E U.
N/A
This is Velleman's:
Suppose that x E U and xRy. To prove that y E U, we must show that y is an upper bound for B, so suppose that b E B. Since x E U, x is an upper bound for B, so bRx...
The proof goes on, but I am stuck at the bolded part. How do we know that the relation R is a relation such that, if x > b, then bRx? What if the relation R is defined as: {(x,y) E A x A | x >= y}? Isn't my definition of R reflexive, transitive, and antisymmetric, and therefore partially ordered, as the given states? And wouldn't my definition then mean that, if x > b, it is not true that bRx? Where am I going wrong?
Thanks in advance.
What you wrote is a partial order, but obviously the author intended this partial order is xRy if x<y
But, taking my literalist, unsubtle (more charitably: rigorous) approach, is my objection valid?
No, it is not. There is no "< " defined. The author is taking "aRb" as the order relation and defining "upper bound" in terms of that relation. Saying that "x is an upper bound on set B then, by definition of "upper bound", bRx for all b in B.
You cannot object to a statement in terms of symbols or relations that have not been defined for that particular statement.
But how is he able to say that bRx immediately follows if x >= all b in B?
I don't think I understand this part of your answer:
He didn't. He said that bRx follows from x being an upper bound for B.
You have thoroughly confused yourself by introducing a second partial order and mixing the two of them up.
If you're studying two orders at once, you really should qualify all order-related terms so you know which order it's related to.
Wait, how is what I said different from what you said? Isn't an upper bound defined as an element that is greater than or equal to every element in some subset?
In other words, how is "x >= all b in B" different from "x being an upper bound for B"?
Yes. But don't confuse the order R with the order [itex]\leq[/itex]. "x is greater than or equal to y" literally means "yRx" in this order!
>_< How can I not confuse R with <= when you've just said that x >= y implies yRx; in other words, x <= y implies xRy!
I never said I am using the word "greater" relative to the ordering [itex]\leq[/itex]!
I think I'm going to re-read the chapter this question comes from. It's pretty clear I don't understand it very well, since I still can't understand the last post!
Topic closed, for the time being, I suppose?
