Why Do Boundary Conditions in a 1D Quantum Box Lead to Different Quantum States?
  • Thread starter Thread starter itssilva
    Eigenstates
The discussion centers on the boundary conditions of a particle in a 1D quantum box and the resulting quantum states. When applying boundary conditions to the wave function, inconsistencies arise between two setups: one from [0, a] and the other from [-a/2, a/2]. The initial confusion stems from miscalculating the coefficients A and B in the wave function, particularly in concluding B=0. The correct approach involves recognizing that the potential's symmetry leads to either symmetric or anti-symmetric eigenstates, and the determinant of the resulting matrix must vanish for non-trivial solutions. Ultimately, the discussion highlights the importance of careful mathematical treatment in quantum mechanics problems.
itssilva
Problem: The particle in a 1D box [0, a]
Eqs.: The general solution of the time-independent Schrödinger eq. may be written as ψ(x) = Acos(kx) + Bsin(kx), E = ħ2k2/2m. Imposing the boundary conditions ψ(0) = ψ(a) = 0 , we get immediately A = 0, ka = nπ (for any positive integer n). Using x' = x - a/2 , plus the boundary condition and elementary trigonometry, we also get ψ(x) = Bsin(kx) = Bcos(kx') , same eigenvalue. Everything is nice and dandy up to now, but, if I start from the box [-a/2, a/2] and impose boundary conditions ψ(-a/2) = ψ(a/2) = 0 , I seem to be getting B = 0, ka = nπ (but this time for odd n only)
What's the reason for this inconsistency? Either in the first case we should take only odd n also, and nobody noticed it in QM textbooks (unlikely), or I'm making some silly mistake, but I can't point my finger where; I've checked the sol. to the boundary condition system many times, it seems fine to me.
You are not doing the maths correctly.
I figured as much; though
ψ(-a/2) = Acos(-ka/2) + Bsin(-ka/2) = Acos(ka/2) - Bsin(ka/2) = 0
ψ(a/2) = Acos(ka/2) + Bsin(ka/2) = 0
=> B = 0 (because symmetry, Fourier series, however you prefer) , cos(ka/2) = 0 <=> ka/2 = (2m+1)π/2
Like I said, it's some silly mistake; but whatever it is, it's in the 3 lines above.
I'm not sure what more of a response you could have gotten considering all you told us was that you got the wrong answer.
Your mistake is in concluding B=0. If you recast the two equations in matrix notation, you have
$$\begin{bmatrix} \cos \frac{ka}{2} & -\sin \frac{ka}{2} \\ \cos \frac{ka}{2} & \sin \frac{ka}{2} \end{bmatrix}
\begin{bmatrix} A \\ B \end{bmatrix} = 0.$$ To get a non-trivial solution, the determinant of the matrix has to vanish. What does that give you?
Likes itssilva
itssilva said:
because symmetry
This is wrong. If the potential is symmetric, eigenstates are symmetric or anti-symmetric.
Oh, I see; indeed, that was naive of me. Sorry, guys; I'm being way over my head for stuff that's supposed to be simple.
Let me note that writing the system in matrix form isn't the way most students would work the problem out. The two equations you got were
\begin{align*}
A \cos \frac{ka}{2} &= B \sin\frac{ka}{2} \\
A \cos \frac{ka}{2} &= -B \sin\frac{ka}{2}.
\end{align*} If you add the first equation to the second, you get ##2A \cos \frac{ka}{2} = 0##. Now you have two cases to consider: A=0 or ##\cos\frac{ka}{2}=0##.
  • · Replies 39 ·
13K
