Path followed by a space station.
5 replies · 2K views · last reply
zorro
Consider a space station orbiting around the Earth in a circular orbit. If it fires its engine radially outward, will it follow a different circular path or an elliptical path?
Since the thrust force is perpendicular to the motion, the angular momentum is conserved. So it should follow an elliptical path.
Is this reasoning correct?
Your answer is correct, but your reasoning is confusing. Why does the fact that angular momentum is conserved mean that it should follow an elliptical path?
V = √(GM/R)
L1 = m√(GMR)
V' = √(GM/R')
L2= m√(GMR')
where,
m - Mass of space station
V - Initial orbital velocity
V' - Final orbital velocity
L1 ≠ L2
So the path cannot be a circle. The other choice is only ellipse (as per the question) :biggrin:
I am interested in knowing the geniune reason though.
Hint: The centripetal force always is: [tex]F = mv^2/\rho[/tex] where [tex]\rho[/tex] is the radius of curvature. If [tex]\rho = R[/tex] where [tex]R[/tex] is the distance between the station and the earth, then the orbit is circular around the earth.
You may want to prove this statement: for a fixed pair of planet M and mass m<<M orbitting around M, for each value of angular momentum L of m, there is one and only one circular orbit corresponding to L.
P.S.: If you want a genuine reason, look at the centripetal force. It's actually gravitational force. When does the gravitational force match *perfectly* with the centripetal force in the case of circular orbit?
L=mvr=m√(GM/r)r=m√(GMr)
For every 'L' there is one and only one 'r'
When they both are equal?
