Path of a Particle: Find & Solve Questions
The discussion revolves around finding the path of a particle under the influence of forces, specifically exploring the relationship between vectors in motion and the implications of initial conditions such as starting from rest.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants express uncertainty about how to start solving the problem and seek to understand the relationship between vectors. Some suggest considering the implications of initial velocity and the nature of the forces applied.
There is ongoing exploration of the problem, with some participants providing guidance on visualizing the motion and suggesting the use of parametric equations. Multiple interpretations of the particle's path are being discussed, particularly in relation to initial conditions and vector motion.
Participants are working within the constraints of homework guidelines, which may limit the information available for solving the problem. There is a focus on understanding vector motion in multiple dimensions.
LoveBoy
Find the path of a particle.
What is the general or fundamental way to solve this type of questions ?
I don't know where do i start.
I can't able to find a relation between these vectors.
Suppose for a moment that the initial velocity of the particle happened to be zero (the particle starts from rest). What type of path would you expect for a constant force being applied?
I've already given you the formulas for vector motion in another post. So, either you don't understand vectors or you don't understand motion in more than one dimension.
Can you draw a crude diagram of roughly what is going to happen to the particle?
Imagine you were running with the initial velocity and someone was pushing you in the direction of the force. Or, that someone is pushing you in the ##\hat{i}## direction and someone else is pushing you in the ##\hat{j}## direction. You need to find some way to relate these things to the real world.
But, then you need the maths to turn a crude understanding into a precise solution. So, if you don't understand vectors, you'd better go back and revise them.
Path will be straight line .
As per your directions given in last post,
Now, how do i find out relationship between them ?
What you have there is a "parametric" equation for ##x## and ##y##. That means both ##x## and ##y## are expressed in terms of a common variable - in this case ##t## or ##t/m## if you prefer. You could plot those on a graph. ##t/m = 0, 1, 2, 3 ...## and see whether that nails down the option between A) to D).
By plotting the graph, i got
s_x and s_y path is parabolic.
That's right. Once you got going with this problem, you seemed to know what you were doing all right.
  • · Replies 40 ·
  • · Replies 30 ·
  • · Replies 23 ·
