How Does Oscillation Affect Capacitor Voltage After Multiple Cycles?
  • Thread starter Thread starter thereddevils
    Capacitors Pd
The discussion focuses on the effect of charge transfer on the voltage of a parallel plate capacitor after multiple oscillations of a metal bob. Initially charged to 20 V, the capacitor loses 10% of its negative charge to the bob with each oscillation. After five complete oscillations, the remaining charge on the negative plate is 0.8889 of the original charge, leading to a proportional decrease in voltage. The relationship between charge and voltage is established, confirming that the potential difference decreases as charge is lost.
  • Understanding of capacitor fundamentals, including charge and voltage relationships.
  • Knowledge of basic electrostatics, particularly charge transfer mechanisms.
  • Familiarity with oscillatory motion and its effects in electrical systems.
  • Ability to apply mathematical equations related to charge and voltage calculations.
  • Study the principles of charge conservation in capacitors.
  • Learn about the mathematical modeling of oscillatory systems in electrical circuits.
  • Explore the effects of varying capacitance on voltage in different configurations.
  • Investigate the relationship between energy stored in capacitors and charge transfer processes.
Students in physics or electrical engineering, educators teaching capacitor behavior, and anyone interested in the dynamics of charge transfer in oscillatory systems.
thereddevils
A parallel plate capacitor is charged by a battery to 20 V and then disconnected . A simple pendulum consists of a metal bob which is suspended by a nylom thread is placed in the middle of the plates of the capacitor . Then the bob is oscillated towards the negative plate of the capacitor . Each time when the bob touches the negative plate , 10 % of the charge at the negative plate will be transferred to the bob and these charges are then neutralised when the bob touches the positive plate of the capacitor . Determine the potential difference between the plates of the capacitor after 5 complete oscillation of the bob .
so i found that 0.1111 of the negative charges have been neutralised and 0.8889 of the -ve charges is left and i am not sure what to do next .
The pd on the capacitor depends on the charge. If it has lost a certain fraction of its charge it should have "lost" the same fraction of its pd.
thanks , am i correct in finding the percentage of -ve charge lost from the plate ? When it says the +ve charge from the other plate neutralise the -ve charge , is the +ve charges also decreasing at the same rate as the -ve charges ?
Yes. If you imagine a charged capacitor that has +10 coulomb on one plate (A) and -10 on the other (B), we say that the capacitor has been charged to 10 coulomb. (Not 20)
If you transfer 1 coulomb of negative charge from plate B to plate A, then plate B has lost 1 coulomb and now has -9, while plate A is now +9. (The one negative charge having neutralised one of the positives.)
The result is that the capacitor now has a charge of 9 coulombs. +9 on the one plate and -9 on the other.
  • · Replies 18 ·
  • · Replies 17 ·
