Pendulum with a mass on a container (thermodynamics problem)
The discussion revolves around a thermodynamics problem involving a pendulum and a mass in a container, focusing on the conversion of kinetic energy into heat and its effects on temperature and entropy within an adiabatic system.
  • Mixed
  • Participants explore the relationship between kinetic energy and temperature change, questioning the validity of equations used to calculate final temperature and entropy variations.
Some participants have provided guidance on interpreting the energy transfer and its implications for temperature and entropy, while others are examining the calculations and assumptions made regarding energy distribution between the iron block and the air.
There are discussions about the assumptions of adiabatic conditions and the degrees of freedom for energy storage in different materials, as well as the implications of the first law of thermodynamics in this context.
ValeForce46
A pendulum, with a block of iron (##m=1 kg##, specific heat ##c=448\frac{J}{Kg\cdot K}##) hanging by a thread (mass negligible), is inside a container of volume with rigid and adiabatic walls. Inside the container there's air (to consider as a biatomic ideal gas) at the atmospheric pressure and at the temperature ##T_0=300 K##. You observe the pendulum has a speed of ##v=3.5 \frac{m}{s}## when the block is on the vertical. After some time, the pendulum ceases to swing. Determine:
a) The final temperature of the system at the end of the oscillation.
b) The variation of entropy of the universe at the end of the trasformation.
##Q=m*c*(T_f-T_0)##
The kinetic energy of the pendulum ##K=\frac{1}{2}\cdot m\cdot v^2## will turn into heat (entirely).
So both the air and the block of iron will change their temperature.
To find ##n## (moles of the gas) I can use the ideal gas law:
##n=\frac{pV}{RT}=0.9 mol##
Do I have the following equation?
##\frac{1}{2}mv^2=m*c*(T_f-T_0)+n*c_v*(T_f-T_0)## and ##T_f## is my unknown.
But I get ##T_f=300K## (nearly). Where's my mistake?
To get a rough idea of the change in temperature: How many Joules of KE does the block of iron initially have?
Note that ciron = 448 J/(kg K), which tells you that it takes 448 J of energy to raise the temperature of the iron block by just 1 K.
##K=6.13 J ##.
So you're silently (not that much :oldbiggrin:) saying that my result ##T_f=300.013 K## is right?
I even doubted my equation.
ValeForce46 said:
##K=6.13 J ##.
Yes, I think your answer is correct. I wanted you to see how you can tell that a very small temperature increase is what you would expect.
Yeah, you made me realize that. Thanks a lot.
However, for completeness, the variation of entropy of the universe is the variation of entropy of the system, because the walls of the container are adiabatic so there's no variation of entropy of the environment:
##\Delta S_{Universe}=\Delta S_{System}=mc(T_f-T_0)+nc_v(T_f-T_0)=6.1 \frac{J}{K}##
Check this calculation. Note that what you calculated here is ##\Delta E_{int}## of the block and gas. It's not surprising that you got 6.1, since the initial KE of the block is 6.1 J.
oops... I did the integral wrong:doh:
##ΔS_{Universe}=ΔS_{System}=m*c*\ln (\frac{T_f}{T_0})+n*c_v*\ln (\frac{T_f}{T_0})=0.02 \frac{J}{K}##
Hope this is right ...
Looks good.
Just a side note: For this problem, you can check that about 96% of the initial KE of the iron block ends up in the iron block and only about 4% goes to the air. That kind of surprised me at first. But it makes sense if you think about the equipartition of energy. In this problem, there are a lot more atoms of iron in the system compared to molecules of air. Moreover, for T around 300 K, each atom of iron has effectively 6 "degrees of freedom" for storing internal energy (Law of Dulong and Petit) compared to 5 degrees of freedom for each air molecule. The energy spreads equally among all of the degrees of freedom in the system.
This is an incorrect interpretation. The kinetic energy of the pendulum will not turn into heat. There is no heat transferred to this adiabatic system. The correct interpretation starts with the full presentation of the first law of thermodynamics: $$\Delta U+\Delta (KE)+\Delta (PE)=Q-W=0$$Also there is not change in potential energy of the system. So $$\Delta U=-\Delta (KE)$$
This tells us the correct interpretation, namely, that the kinetic energy of the pendulum will convert directly to internal energy (via viscous dissipation by the air).
Since the temperature hardly changes, the change in entropy is nearly exactly the initial kinetic energy (6.125 J) divided by the temperature, roughly (300 K), or 6.125/300 = 0.0204 J/K.
  • · Replies 17 ·
  • · Replies 27 ·
