Percent change in thermionic emission
benben312000
% change in thermionic emission
Q1. Determine the % change in thermionic emission for an oxide-coated filament of work function of 1.3eV if the temperature is decreased by 1.00% at a temperature of 2300K
I'm uncertain but i used
dJ/J=dT/T ( 2 + ((1160x1.3)/1000)
to get a 15% change in current density. I'm not really good at this so i not sure if i used the formula correctly
Q2. Calculate the % change in therimonic amission from tungsten filament of work function 4.52eV if the work funtion is decreased by 1.00% at a temperature of 2300K
I was really puzzled by this question as the difference is in this question the work function is said to decrease but i do not know how to calculate the % change.
Thanks in advance for all the help given.
Use the old (1901, Richardson) formula for thermionic emission:
J = K(T^2)exp(-W/kT),
J = thermionic current density
K = constant peculiar to emitting oxide,
W = work function of oxide
T = temperature, Kelvin.
Thanks lots Rude man o:)
Hmm that's interesting i came across a Richardson-Dushmann law as well but it's not so similar, but that's how i get the "dJ/J=dT/T ( 2 + ((1160x1.3)/1000)". But it's differentiate with respect to the absolute temperature.
Btw do u mean i could use the same formula for both the question cause i don't understand the 2nd question.
Thanks once again
Thanks once again
Yes, the formula isused for both of your questions. Just need a bit of calculus:
dJ/J = (1/J)∂J/∂T*dT + (1/J)∂J/∂W*dW
For your 1st problem, W is constant.
For your 2nd problem, T is constant.
Away you go!
PS - from Wikipedia: "Over 60 years later, there is still no consensus amongst interested theoreticians as to what the precise form of the expression for K should be ... "
PPS - for you that makes no difference since K will cancel out when you divide by J.
