What are the 10th percentile and z-score for a set of eye measurements?
  • Thread starter Thread starter n77ler
The discussion focuses on calculating the 10th percentile and the z-score for a set of 25 eye measurements from university students. The 10th percentile is determined to be 0.06, which is the third value in the ordered dataset. The z-score for the measurement of 1.07 is calculated using the formula z = (x - mean) / standard deviation, where the mean is 0.1544. However, the initial calculation of the z-score was incorrect due to the use of the sample size instead of the standard deviation in the denominator.
  • Understanding of percentiles and their calculation
  • Knowledge of z-score formula and its components
  • Familiarity with basic statistics concepts such as mean and standard deviation
  • Ability to interpret statistical results in context
  • Review the calculation of percentiles in statistical datasets
  • Study the correct formula for calculating z-scores, including the use of standard deviation
  • Explore the concept of outliers and their impact on statistical measures
  • Learn about Venn diagrams and probability intersections in statistics
Students studying statistics, educators teaching statistical concepts, and anyone interested in understanding percentile and z-score calculations in data analysis.
n77ler
The following 25 measurements were obtained on the eyes of over 100 university students.
0.04 0.06 0.06 0.06 0.07 0.07 0.08 0.08 0.09 0.09 0.09 0.10 0.11 0.12 0.12 0.15 0.16 0.16 0.16 0.17 0.17 0.17 0.20 0.21 1.07
a) Find the 10th percentile of these measurements. Interpret the result
b)Calculate the z-score for the measurement of 1.07. Interpret the result.
I= (P/100)n
P defined as percentile
n defined as #of measurements
I= (10/100)25 = 2.5 Round up to 3. So the 10th percentile is the third value when rearranged from smallest to greatest. It ends up being the second 0.06 value in the set. So how do I write the final answer? Do I just circle the third value?
z-score needs mean. x(bar)= sum of all numbers/ number of measurements
mean= 0.1544
z-score= (1.07-0.1544)/25 = 0.0366 but this seems a little small for a z-score doesn't it? when the number is much bigger(or the outlier) than the rest of the data?
for the second problem - check your formula for a Z-score.
opps is it supposed to be the deviation on bottom?
Another little question. If I had a venn diagram and the two circles in it were labelled A and B and they weren't mutually exclusive and I was asked to give the probability of
A and B intersection but A is a complementation. I think it is 0 because there can only be values where the circles overlap and the complementation will have no values.
Re the Venn Diagram question: break your question down into sentences and write it more clearly because:
  1. It isn't immediately clear to me what the core question is
  2. Doing so will help you organize your own plan of attach, and
  3. Having your own plan of attack will allow you to provide more information on your attempts to solve the question, which you need to provide before I can help you with it
For the Z-score question: look in your stat book, or notes, or both, for the definition of a sample Z-score - that will clarify the denominator. (word of advice: the denominator is neither the sample size alone nor the standard deviation alone)
My textbook shows the denominator as 's' which is the standard deviation? And that's it , nothing else.
  • · Replies 18 ·
