How Can I Learn About Permanent Magnet Field Strengths and Interactions?
  • Context: High School
  • Thread starter Thread starter Wingwalker
    Magnet Permanent magnet
This discussion focuses on learning about the field strengths and interactions of permanent magnets, specifically ferrite and neodymium magnets. The user seeks resources to understand magnetic field strengths without access to a gaussmeter and inquires about the interactions between multiple magnets in both attractive and repulsive scenarios. Key insights include the importance of manufacturer specifications for rated strengths and the suggestion to use a coil of wire as an electromagnet for comparative measurements. The discussion also highlights the complexity of magnet interactions and the need for simplified geometries in calculations.
  • Basic understanding of magnetic fields and their properties
  • Familiarity with neodymium magnets, specifically N35 grade
  • Knowledge of electromagnetism and magnetic induction principles
  • Ability to interpret and visualize 3D data representations
  • Research the equations governing magnetic field strengths for permanent magnets
  • Explore the use of coils in electromagnetism to measure magnetic fields
  • Investigate existing studies or formulas for calculating magnetic field shapes and strengths
  • Review Wikipedia articles on permanent magnets and electromagnets for foundational knowledge
This discussion is beneficial for hobbyists, physics students, and engineers interested in understanding permanent magnet behavior, as well as anyone involved in projects requiring knowledge of magnetic field interactions and measurements.
Wingwalker
Im looking to do some projects with permanent magnets.
I don't have access to a gaussmeter and I'm wondering if there are any sites that have representations, descriptions or formulas for the field strengths of ferrite or neodymium magnets.
Also i need to learn about how magnetic fields from permanent magnets interact with each other in attractive and repulsive situations containing mulitple magnets.
Im guessing I am going to have a lot to learn as I have no formal physics education.
Any help enabeling me to understand this concept would be appreciated.
Welcome to PF;
The interactions of magnets is very complicated unless you strive to keep the geometry simple.
Computing the field strengths of magnets is also not easy.
So the details will depend a lot on what you want to do with them.
Manufacturers will often tell you a rated strength for their products - read carefully.
The equations for electromagnets and magnetic induction are (a bit) easier - if I were you, I'd use a coil of wire to measure field strengths and run it as an electromagnet to compare strengths.
Try the wikipedia articles for permanent and electro-magnets as starting points.
Hi Simon,
Thanks for the reply. So, I have a N35 neodymium magnet 12mm x 12mm x 6mm with north and south being on the opposing 12 x 12 faces. If I were to plot out in 3d space the strength of the field at that a particular point and assign a colour to that point (red and blue for example) to represent its polarity then I could build up a visual representation of the magnet and its field. If I then repeated this for 3 other magnets of the same grade and same size but with one dimension changed, say changing 6mm to 12mm then 24mm and lastly 48mm I would get a get a data set that I could then use to determine the strength and field shape of a magnet that is 16mm. Correct?
I'm hoping that I am correct and his has been done before and there is some formula that can calculate this without me having to purchase a gaussmeter and do it myself, it seems pretty basic.
I'm reading through the wiki also
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 27 ·
