Permuations of identical items
7 replies · 2K views · last reply
mr.tea
There is a book with 2 volumes. Each volume exists in 3 different languages. Each language has 2 identical copies(total of 12 books).
In how many ways we can arrange them on a shelf, with no restrictions and order of the volumes is irrelevant?
I thought that since we have 12 books, we can arrange them in ##\frac{12!}{(2!)^6}## but apparently it is not correct. The correct answer is ##\frac{12!}{6!}## but I am not sure why.
What am I missing?
Thank you.
In how many ways we can arrange them on a shelf, with no restrictions and order is irrelevant?
What am I missing?
Thank you.
You're missing an attempt at the solution, so we can see where you go wrong.
PS as the question is stated, I would say the answer is 1. If order is irrelevant, then you have the same 12 books on the shelf in all cases.
PeroK said:
PPS I agree with your answer! If you assume that order is relevant.
I have just edited that the order of the volumes is irrelevant... does it add any information?
That doesn't make a lot of sense to me. If books are on a shelf, then the order defines the arrangement; otherwise, as I said, you only have the one set of books. It's different if two books are identical, then you can swap those without changing the arrangement. But, if you swap Volume 1 and Volume 2, by definition you have a different arrangement of books.
I'd be happy that you solved the question the sensible way. I wouldn't get too hung up on what precisely the question setter had in mind in this case.
Well, we have 6 sets of books, each set consists of 2 identical books. Like: ##A_1,A_1;B_1,B_1;C_1,C_1;A_2,A_2;B_2,B_2;C_2,C_2;## where the 1's and 2's refer to the volume(vol1 or vol2). That's the case the question talks about. So I can't understand why my answer is not correct... Maybe it's not me?
This is why you should have posted your working in the first place. You can swap the two ##A_1##'s etc. without changing the order. That's why I thought you got ##\frac{12!}{(2!)^6}##.
I can't make sense of the order of volumes not being relevant. If you interpret that as ##A_1, A_1, A_2, A_2## can be in any order, then you'd just get ##\frac{12!}{(4!)^3}##.
