Permutation question (math) [ ]
  • Thread starter Thread starter F|234K
    Permutation
The discussion revolves around solving a permutation problem involving paths to vertices, where the correct answer is indicated as option c. The initial approach using the formula 10!/(4!6!) is questioned, with participants suggesting a method of summing the ways to reach each vertex. A participant illustrates the process by filling in values for the vertices, explaining that the number of ways to reach a vertex is the sum of the ways to reach its preceding vertices. Clarifications are provided regarding the interpretation of a "park" as a blank space, affecting the calculation of paths. The conversation concludes with participants gaining understanding of the relationship between the vertices and the number of ways to reach them.
F|234K
permutation question (math) [urgent]
image here
please solve this problem for me. the correct answer is c.
i put 10!/(4!6!), then i know i am suppose to divide/subtract something, but i don't know what. (i have never done this kind of problem before.)
hell I am stumped...
You can just add up the ways to get to each vertex. Here are the first few (period represents a vertex, number before each vertex is the number of ways to get to it):
Code:
1. 1. 1. 1. 1.  .  .
1. 2. 3. 4. 5.  .  .
1. 3. 6.        .  .
1. 4.10.  .  .  .  .
See what I'm doing and why?
somebody please help
but how u going to get the numbers for the dots in the park!
i did try to solvei t using pascal triangle thing...but i got stuck on the park thing...
There are no dots in the park. And it's not exactly Pascal's triangle because of the park. Here's a hint (some more vertexes filled in):
Code:
1. 1. 1. 1. 1.  .  .
1. 2. 3. 4. 5. 6.  .
1. 3. 6.       6.  .
1. 4.10.10.  .  .  .
Im guessing the park is considered as one big square.
No, the park is considered a blank. The number of ways to get to any vertex is equal to the sum of the number of ways to get to any of the immediately preceding vertices.
why u have a 10 after the 10? how the get the second 10?
For example take the first 10 you get, at vertex (4, 3) by row, column. At vertex (3, 3) you have a 6, and at vertex (4, 2) you have a 4. You can get to the 10 one of two ways: through (3, 3) by going south, and through (4, 2) by going east. There are 6 ways to get to (3, 3) so there are 6 ways to get to (3, 3) and then go south. There are 4 ways to get to (4, 2) so there are 4 ways to get to (4, 2) and then go east. So you have 4 ways + 6 ways = 10 ways for vertex (4, 3).
If a vertex only has one other vertex leading into it--say the other vertex has 7 ways to get to it--then how many ways can you get to that second vertex?
oh...i think i got it...thanks for this "If a vertex only has one other vertex leading into it--say the other vertex has 7 ways to get to it--then how many ways can you get to that second vertex?"
again..thanks alot!
  • · Replies 22 ·
