Perpendicular Graphs: Finding A1/B1 Using Negative Reciprocal | Homework Help
When two lines represented by the equations A1x + B1y = C1 and A2x + B2y = C2 are perpendicular, the slopes are negative reciprocals of each other. The correct expression for A1/B1 in terms of A2 and B2 is -B2/A2. There is confusion regarding the correctness of this expression, with some users feeling that it should not be marked incorrect. The discussion highlights frustrations with online homework systems misgrading correct answers. Understanding the relationship between the coefficients is crucial for solving problems involving perpendicular lines.
eXmag
If the graphs of A1x + B1y = C1 and A2x + B2y = C2 are perpendicular, express the following in terms of A2 and B2.
A1/B1= ?
Negative reciprocal
I thought that by expressing A2 and B2 with A1/B1, it would just be the negative reciprocal if its perpendicular so it would be -B2/A2 which is incorrect.
A1/B1= ?
Negative reciprocal
It shouldn't be marked as incorrect. It looks correct to me.
This is how webassign screws you over!
Thanks for the response! I knew it was correct
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
